This ain’t right…
Old Jul 16, 2022 | 01:41 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
This ain’t right…
The beast has been been siting for a while, and as a result the petrol pumps needed replacing. Upon inspection we discover a thin puddle of oil on the bottom of the petrol tank. Anyone have any ideas? In my view it appears to be sabotage.
The car was running progressively worse prior to being taken off the road - could this have been the issue?
Oil in bottom of petrol tank!
Old Jul 16, 2022 | 02:14 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Weird, as I have no idea where oil could enter the fuel system/loop (without sabotage). The only thing I can imagine would be the fuel filler flap...
Old Jul 16, 2022 | 02:19 PM
chassis's Avatar
2017 GLE350 4MATIC
Do you have reason to believe that sabotage is a possible reason for oil in the fuel tank?
Old Jul 16, 2022 | 05:01 PM
The last mechanic that worked on the car prior to it going off the road is potentially a culprit. I met him through a friend who (as it transpired) had mental health issues and thought we were all conspiring against him. At any rate, the mechanic ended up charging an excessive amount and holding the car for ransom. When I paid him (extortionist rates) the car was returned with a broken door moulding and the oil cap missing; it’s reasonable to consider he could have caused other damage also. 😖
Old Jul 16, 2022 | 05:03 PM
I agree; that’s the only possibility i could think of…
Old Jul 16, 2022 | 05:22 PM
chassis's Avatar
2017 GLE350 4MATIC
Sorry to hear. If oil is the "only" damage, is it possible to wipe up as much oil as possible, put everything back together, and fill the tank full with petrol? The idea is to dilute the remaining oil residue. The engine might run like crap for a while. The catalysts might take some abuse also.
Old Jul 17, 2022 | 01:23 AM
Thanks for your input. From what I can see, pretty much all the oil can be cleaned from the tank interior. I intend to fill her with fuel then let her just sit and idle for a while. I expect.that she’ll run rough initially but fingers crossed, the ecu should gradually adjust itself after being thrown out trying to cope with the irregular fuel prior to going off the road.
hopefully cats are ok. Only the primaries are in place and they are almost new. No resonator either as they have been replaced by an x-pipe.
Old Jul 17, 2022 | 07:30 AM
Hrvstr1's Avatar
2002 S430 and 2005 E55 AMG
Oil and fuel won’t mix. There will be no diluting. The oil will just float on top the fuel.
Old Jul 17, 2022 | 08:19 AM
chassis's Avatar
2017 GLE350 4MATIC
How does a 2-stroke engine work?
Old Jul 17, 2022 | 08:44 AM
Haha exactly, back in the day I had a 2-stroke engine scooter (Kymco DJ Y50) and you had to add oil to the fuel for lubrication.
2-stroke engines use a total-loss lubrication system that combines oil and fuel to provide both energy and engine lubrication. The oil and fuel are combined in the cylinder’s intake tract and lubricate critical components such as the crankshaft, connecting rods and cylinder walls.
source: https://blog.amsoil.com/applications...ication-needs/
Old Jul 17, 2022 | 10:23 AM
Hrvstr1's Avatar
That’s a good point. My brain was turned off for that one.
