Crazy uneven tire wear one 1 rear tire. How does this happen?
Full story: I absolutely knew that my rear tires were on the end of their life so naturally I decided to have a little burn out fun before I go get new tires. I suppose that I would not expect one tire to wear like this but then again I was doing donuts. Do you all think this is a result of burnouts or should I have something to worry about?
I have had regular dealer alignments, I dont drive the car often, and have always noticed that they wear evenly before now.
Just wondering if I need to get things checkout before I get new rubber. Thanks!
Pics: https://imgur.com/gallery/vFJ9LDn
Now, the interesting part, this is my second 211 e63 non p30 stock. The old one never had this wear pattern ever, it was always rather even and I can see from the outside corner tread how bad my tires were.
In my google research I believe the w211 or at least these AMGs have a neg camber purposely to aid in performance when cornering/handling, and its rather know to have a lil more wear on the inside. Esp more wear on inside if you drive hard and straight.
Im not telling it as it is, just wondering what someone thinks of the situations we are in.
Also is your car lowered, as that would also explain it. I would first have your car re-aligned, to see how badly your alignment maybe off. Before you start replacing suspension components.
As a result my rears showed slightly more wear on the inside. But nothing to the degree that you explained. But, now that I have a entirely new suspension under it now, my wear issue should be none existent.
Unless your just out in a parking lot doing donuts and burn outs.
No Camber or Caster allowing to adjust tire contact angles, spread load more evenly to correctly resolve costly, premature edge tire wear.
It is as simple as that. Alright for showroom height conditions but day to day commuting encountering high cambered roads with more right hand side edge tire wear. Or wheel squat through load carrying or lowering, fitting wide profile tires or not being able to compensate for curb knock damage.
Camber and Caster adjustment is essential - FIXING IT RIGHT THE 1ST TIME.
No more the frustration of going from one dealer or alignment shop to the next or resorting to constantly changing tire brands.
W211 All incl. AMG & 4MATIC
See Spoiler
AUDI to VOLVO - KMAC Experience Of Resolving OEM Suspension Shortcomings Since 1964!
