W211 facelift airbag cover removal?
Old Oct 7, 2022 | 09:22 PM
MJBelcher500's Avatar
2006 E55
So, I installed a W211 E63 steering wheel in my 2006 E55, Everything seems to work, but when pushing on the airbag cover, below the center of the star, there seems to be a gap. It feels like there is space between the cover and the airbag itself so the cover material wrinkles slightly before the horn is activated. Is this normal on older airbags? Can I remove the cover from the assembly and add something like a high density foam?
Old Oct 8, 2022 | 04:14 PM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
Post a picture of your setup
the airbag cover does come off but its a pain in the ***.
Old Oct 8, 2022 | 07:14 PM
2006 E55
Old Oct 8, 2022 | 07:18 PM
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
I wouldn't fiddle with the airbag. Especially not the area that is supposed to break in case the airbag has to deploy.
Old Oct 8, 2022 | 07:20 PM
2006 E55
At a minimum I would like to remove the cover to see what is under it. It does not see correct that there is so much space between the cover and the airbag itself.
Old Oct 10, 2022 | 10:12 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
There is a gap, trust me. When, I received my new Alcantara wheel, it was the same. If you remove the airbag, you will see the gap, this is for airbag expansion.
If you need to activate the horn push the horn symbols at the top of the wheel.
Attached Thumbnails W211 facelift airbag cover removal?-img_4419.jpg   W211 facelift airbag cover removal?-img_4437.jpg   W211 facelift airbag cover removal?-s-l1600-10-.jpg   W211 facelift airbag cover removal?-s-l1600-11-.jpg
Old Oct 10, 2022 | 10:24 AM
2006 E55
Thank you for confirming this. If it is normal, I will leave it alone.
