Rear O-2's
Old Jul 11, 2023 | 07:50 AM
SICAMG's Avatar
2005 e55 AMG
Rear O-2's
Anyone have the trick for shutting off the rear O-2 sensors.
Looking to put my cat delete down pipes on for the next race and cannot get it to code out. When I send the coding change in DAS it says communication failure.
I am doing it with the car running and there are no codes lingering around to prevent it. Wondering if the MIL light stays on it would affect anything aside from the ECU seeing they are sending an over-map reading ?
Old Jul 11, 2023 | 08:07 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
You can always try O2 spacers?
Old Jul 11, 2023 | 09:25 AM
SICAMG's Avatar
2005 e55 AMG
I did and it ran horrible. It actually threw the car in limp mode and would make up shift in M mode no matter what at 3,000 rpm. The AFR was all over the place as well. I have used them before and never an issue with other cars but who knows...
Old Jul 11, 2023 | 10:02 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Code them out. Multiple posts. Advanced search on code out O2 sensors. Also in STAR stickies but buried deep. Search first.
Old Jul 11, 2023 | 10:55 AM
SICAMG's Avatar
2005 e55 AMG
Code will not send to the control unit and says "failed"
Old Jul 11, 2023 | 12:10 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
They won't code out with the "developer kit"? Or they code out and throw an error code?
Old Jul 11, 2023 | 12:26 PM
SICAMG's Avatar
2005 e55 AMG
Will not code out with developer. It says "failed to send codering".
Very odd since I have done other things with the system with no problems and from what I have seen the countless other guys doing it when cat deleting.
Old Jul 11, 2023 | 12:33 PM
Ah ok clear, then coding out is the only and best solution indeed. Good luck buddy, unfortunately I dont have the knowledge about this.
