2003 E55 Fuel Sender Struggles
Old May 21, 2024 | 01:33 PM
Felix10's Avatar
E55 AMG w211
Exclamation 2003 E55 Fuel Sender Struggles
Hi there,
This is my first post so apologies if this has been discussed before.
I've recently purchased a Japanese import E55 2003 and I've bought a new set of fuel pumps as the old ones had seized.
The fuel sending unit was also damaged so I need to replace it, however the parts seem to hardly exist and if they are available they are ridiculously priced. So is it possible to use a fuel sender from a 1.8 - 5.0l W211? The only differences I can see are some different hose connections (which I can replace with the old ones) and some different styling. These senders are a fraction of the price too.
If this is not possible, then can I use the newer style sender unit with the additional sensor on top and leave it unplugged?
E55 Correct fuel sender: 2114705094
E55 Newer style fuel sender with extra connector on top: 2114706494
W211 1.8 - 5.0l sender: 2114703994
Any thoughts would be very appreciated!
2114705094 Correct pump
1.8 - 5.0l sender 2114703994
Old May 21, 2024 | 02:51 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Just get the ECS refurbished unit and call it a day (first part number).
R.K.
Old May 21, 2024 | 02:59 PM
Felix10's Avatar
E55 AMG w211
R.K.
I did speak to them yesterday and they said they don’t have any in stock. The guy I was speaking to was fairly unhelpful though so I’ll try again. Thanks
Old May 21, 2024 | 03:08 PM
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
NA has 3.8bar fuel pressure, AMG has 5.3bar. Too low fuel pressure= lean mixture= engine block damage
Old May 21, 2024 | 03:26 PM
Felix10's Avatar
E55 AMG w211
Thank you Uncle Ben, that was my worry. Looks like I'll be buying the expensive one.
