Snow tire fitment question
1989 Toyota Tercel Coupé
I am looking to buy some Nokian tires for my 63. Would I be able to put 245s on the rear? The tires I am looking at would be 245/45R19 all the way around. The next size up would be 255/40R19 but is it a good idea to run staggered for snows?
Click here:
https://mbworld.org/forums/w212-amg/...ter-tires.html
See the last two posts. Probably would keep the same widths front and back if you are going with winter tires. Don't know what the staggered configuration is going to get you esp when the widths are only 10mm apart. Generally for winter tires, lower tread width is better for traction on snow.
Narrower is better for snow, a wider tire will plow and push the snow and eventually "float" on the snow (like a snow shoe) as where a narrower tire will slice through the snow and actually generate more traction than a wider tire. This will be very noticable especially while braking and turning. I know it sounds backwards but trust me, 25 years of driving in Chicago and midwest winters has taught me a thing or two.
My ex-cars: 03 E55,04 C32, 05 C55 ,03 E320
Does anyone think I will have a problem putting 255/40/R19 all around instead of 255/35/R19 all around like the manual suggests? Nokian only makes tires in the first size.
Anyone? The guy at the tire shop said they wouldn't fit because our rears are 10.5" but the manual suggests that size for my 19" rims.
cant see why not. its kinda confusing the answer he gave you though. from a width perspective it should be fine. Others on here have 255's all round so i'm not sure why he's telling you 10.5 vs 9.5.as a reason for not fitting. you are going up in diameter tho but its marginal. thats my opinion
