Optimal RPM for E63 AMG from complete stop?
Old Mar 31, 2011 | 07:35 PM
siamesecat's Avatar
2011 E63 AMG
Hello all,
Long time lurker first time poster. I recently got an W212 AMG Steel color and am loving it.
I have a quick question re 1/4 mile striaght line races. What I'm doing now is using manual mode, left foot on the brake, right foot on the gas and rev the engine to 4k RPM in 1st gear. Release left foot allow engine to barely hit redline then upshift.
Is 4k RPM optimal for this particular car or should I rev it higher? I use 4k RPM because in the instruction manual it tells you to rev the engine up to 4k in Race Start mode.
However, I'd rather not use the Race Start mode for obvious reasons (too long/troublesome to initiate, cancels easily, 0.5s lag).
Any advice would be welcome!
Sincerely,
Siamesecat
Old Apr 1, 2011 | 04:48 PM
bushburninc63's Avatar
2009 c63, 2010 E63
1,500 to 1,800 rpms are usually good.
Old Apr 2, 2011 | 01:44 PM
siamesecat's Avatar
2011 E63 AMG
Thanks for the reply, that was lower than I expected. Did you actually test these rpms and they are faster than 4k+?
Also do you have the EPS to off or sport?
I read on a review site that using RS versus the above method only increases 0-60 time by "hundreth" of a second; it's not a big deal to me.
Old Apr 2, 2011 | 03:47 PM
CAracer's Avatar
GTS AMG
I've tried both RS and power braking @ 3000 rpm and got identical times at the track. So the RS is pretty good.
Old Apr 15, 2011 | 01:58 PM
2009 c63, 2010 E63
I was basing my assumptions on the c63, but the tranny on the e63 is different, so I might be wrong. sorry :o
Old Apr 17, 2011 | 08:31 PM
93turbocoupe's Avatar
2007 E63
How do you put your car in race start
Old Apr 19, 2011 | 12:35 AM
siamesecat's Avatar
2011 E63 AMG
Rather than typing this out, you can just look here:
http://www.mbusa.com/mercedes/servic...owners_manuals
Click on the 2011 E Sedan manual, RS mode is described on pg. 191.
Old Apr 19, 2011 | 10:51 AM
2007 E63
will this work on a 2007 e 63?
Old Apr 27, 2011 | 04:28 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
See the W211 thread.
I think it is:
S
Select 1st
Ride height up for weight transfer to rear.
Hire <100 lb driver.
Soft tires in rear
40+ PSI in front
-20,000 DA (LOL)
