HK Stereo - what can be done to improve?
My only dislike with this car is the stereo - anything that can be done at a reasonable price?
What settings do you use? Right now I'm at 0 treble and -4 bass and Logic7 On and that seems to be the best I've found so far .
AMG GT S & E63 S AMG
Same question here. On my F10 BMW, I upgraded their HK system with some plug and play speakers from Bavsound and it sounded much better. Anyone know of similar upgrades for MB?
2019 E63 S
I just despise my HK. I am still contemplating a real stereo upgrade. The Burmester in my 991 Turbo S is so much better. I miss my BMW 550xi's HK which was world better than my E63s (the only thing I miss about the 550).
2020 E 300 Coupe and 2019 GLS 400
IMHO Mercedes is a failure in regards to sound systems. The whole system is removed and replaced with Focal Elite K2 components(Amp, Sub, Speakers). Expensive, but worth every single $$$.
The strange thing is the standard HK system in my wife's GL550 has none of these problems. The clarity is tremendous and bass is adequate. The HK system in the E63 is muddy and clearly lacks separation.
2015 CLS63 S
So has anyone found a workable solution to replace HK yet?
I was thinking along the lines of keeping the head unit and replacing speakers and amplifier, plus installing a digital processor, but i think there is some sort of fiber bus link between head unit and the amp. Plus the amp also controls the voice functions of command.
Has anyone here figured out components that work with the head unit? I talked to a local shop and I seem to be more knowledgeable than they are on how command works with the amplifier thanks to this forum...
2018 S560 and 2019 E450 Wagon.
I wonder if the sound system sounds better in the wagons because my 2012 wagon is not bad and I do like a good sound system, I find it acceptable. It is much better than my last car, a 2013 Cadillac CTS-V. I would say my 2013 VW Jetta Wagon sound system does sound a little better though than the Benz, I'm very happy with that sound system. I can't really see spending the time and money upgrading the speakers in the Benz like I have done in so many cars.
Wow, I am having none of those issues. I have mine sent to Logic 7 on, Treble +4 and bass +7. I listen to mostly rock and metal, sounds crisp and clean. Only gripe I have is with the crappy antenna, local radio reception and local HD radio is crappy.
The problem with that is you will likely end up stressing the speakers trying to push all that bass into them. Better to spend the 200 bucks and install a sub in the trunk so you don't have to overstress the speakers.
I disagree completely. Burmester 3D in the S Class annihilates most other factory audio systems.
Mine are set to Logic 7 ON, Treble +4, Bass +10, Fader -3 (more on the rear)
Doctor ! Help, My speakers are stressed !!!
