More than +$15,000 Later
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
As a child, always wish for a Lambo. Now I have a luxury 4 door sedan that can go head to head with one and win.
Received 3,419 Likes
2012 CLS63
go for ELM if you do
And btw to OP: your car looks effing great Bro! Not a white fan normally, but your car looks great!
Cheers!
Received 2,162 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I can beat David to 60ft on stock rubber from a dig with 4matic, then he's got me beat ... But I OWN the first 60ft lolol
Thanks. Got H&R spring and links sitting in the garage, but not sure if that is the best way to go for me.
Did you do the same or did you go another route ?
The way I understand it, my back wheels/tires is current sitting about a finger and a half (1 1/2 fingers ) from the back fenders and the fronts are about 3 fingers from the front fenders and the way I understand the rear airmatics lowers itself after reaching certain speed so if I lower the front with springs and it should sit flush with the fender, but the rear links will be too low especially when it reach that certain speed which then will rub.
Any thoughts or suggestion would be appreciated. Thank you.
#33
http://www.ebay.com/itm/2-x-Laser-LED-Door-courtesy-Shadow-Projector-Light-For-Benz-w176-A-class-A45-AMG-/301604137111?hash=item463901e897&vxp=mtr
Thank for your complement. Any mods in the Horizon for your girl?
#34
Have had the opportunity to race a couple of facelift E63s and I do get that jump start off the line.
#35
Bro. No disrespect, but keep in mind the ECU tune elimates ( not completely, but enough to get the jump start needed ) the lag from the green light that stock E63 including my original stock E63 encounters and mine does have the limited slip to balance the power to all 4 wheels.
#38
2012 CLS63
electronic lowering module
#39
The very cool thing it does do is maintain a steady ride height on the rear. Yours will end up having a ride height like mine - you'll fit the springs (and I recommend you do the springs first, then wait and do the rears after a couple of weeks if you can handle the strange look of having the front raked) and notice that the drop is more than 20mm, but it's still very cool. You'll then want to match the rear, which you can do with the links (shorter links == lower car btw - this will come in handy when you do the install). Once you've matched the rear, you'll be like...damn that looks good but what will I do once the wife n kids get into the car - it'll rub!! But no - when the car detects weight/load in the rear, it will raise itself to the new 'default' position of the car. When the rear lightens up, it'll go back down but only as far as you've set it to. I love this feature. you maintain a perfectly level ride height at all times
#40
Nope, had a great day actually. I was cracking a joke about beating you off the line and tried to imply that with the "lolol" and emoticon and you then went into the "actually, bro, ... I've raced x, y, z... And a diatribe on why I was 'wrong' " I've always appreciated your posts and insight into these beastly machines and I don't see why that has to change.
So I'll end with this, congrats on your car and what you've accomplished with it, be safe and have fun!
Regards
#41
David
Regards
Regards
#42
Many thanks and am sorry if I misinfomed people.
#43
Hyperion. Do you mean the Renntech or KW ELM? If so what would you recommend ? I wanted to be able to lower or rise my car electronically while in my car and not take it to a shop where a pro has to do it for me, but was told the Renntech or KW doesn't work for my 2012 model. Please kindly cleaify if possible with recommendations. Many thanks.
#44
2012 CLS63
I cannot speak directly to the quality or ride comfort; but if I was going to drop my car, I'd go with an electronic device versus cutting springs and what not, then again, I know nothing about lowering cars.....plenty of cats here that do though
#45
I'm fairly sure that this one doesn't do that because it doesn't have air springs on all four corners, ie the rear would be sagged down and probably create more drag on the highway.
Last question. Is it possible to install the springs and links at the same time just ask the shop to adjust the link to its highest possible position and see how that goes and adjust the links as I see fit?
Many thanks.
#46
Question, is that the Renntech front lip you have on? How easy was the install? I currently have the OEM front lip spliters and ???... Thanks.
#47
2012 CLS63
it is, a three piece lip.......install was done at the indy but it was simple, cost me 3800 pls install
#49
2012 CLS63
sorry if I was not clear: it is a Renntech 3 piece front lip, I have pix in my album I think, probably none from install though
