More than +$15,000 Later
#176
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
Hi. Many thanks for your compliment.
The specs you listed below were for my old 2011 E350 so you do not want to use that spec. for your E63. The reason I had to add spacers was for that exact reason the specs you've listed does not sit flush with the fenders.
You want to get new wheels with the following specs.:
20x9+32mm
20x10.5+42mm
This way you do not need spacers which is what I recommend.
Tires, I just purchased a set of Michelin Pilot Super Sport ( PSS ) with the tire specs you've listed above however I would recommend lowering it since it will sit on low profile tires as listed and the gaps will look out of place ( to me ).
Good luck and feel free to let me know if you have any other questions.
20x9+32mm
20x10.5+42mm
#177
I should change the subject to more than $30,000 later, but happy to report I just got the AMS Alpha 9 full tune. Now this is how AMG should of made it out of the factory. For those that are thinking of going that route, do not hesitate. It is a rocket.
#178
Hey guys, any install the TCU upgrade from Weistec 722.9 Valve Body ?
If so your opinion would be greatly appreciated. Did it improve the throttle lag of the line?
Many thanks.
Many thanks.
#180
I would say a 20% increase from stop to 40mph, from 40mph and onwards, it's a rocket. The car pulls really hard on the mid to high range. Just hope the transmission was more in line with the M6 so wanted to know if the TCU tune would help my E63?
#182
Thanks Jose. Having my fingers cross that will eliminate at lease 50% of the throttle lag of the line. Looking forward to your review.
#183
Really wish AMS did an upgrade on the TCU. That would have been my first choice. Really like the throttle responds on the M6 and hope a TCU upgrade will do the trick. Crossing my fingers.
#187
It's the actual valve body. Here is the link I am looking at:
https://www.vividracing.com/catalog/...150907182.html
I'm looking forward to Joseyu or anyone was has this upgrade and their assessment of it.
Many thanks.
Many thanks.
#189
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i dont think this is going to help with the off the line acceleration as that is the torque limits that MB has embedded in the ecu/tcu that no tuner has found a way around yet that i have heard of yet...
this valve body upgrade will just change time between shifts... not engagement from a stop
#191
What would be the benefit for this TCU upgrade ?
Hope to hear something positive from Joseyu when he gets his car back from this upgrade or I would be disappointed.
#193
No the response off the line is partially wet clutch engagement and partial torque limiting from Ecu.... Once the car is going then yes, shift from 1st to 2nd and so forth will be faster but I think that 1/2 second of hesitation from standstill will not be eliminated and that's what's killing 0-60 ft times ( which is all in 1st gear so faster shifting times is not relevant to that point )
#194
