AMG Button not working
Old Sep 19, 2015 | 02:03 PM
cyclezib's Avatar
s4
When I push the AMG button, the car stays in "C" mode but does change the suspension.
Is there a setting on the dash display that I may inadvertently changed which prevents AMG mode? The engine is in the correct temperature range for AMG mode.
Your insight is appreciated.
Old Sep 19, 2015 | 02:12 PM
Mixedfruits's Avatar
E63 Black on Black
The amg button is like the memory seat function, once you adjust your c-s-s+-M mode, your suspension stiffness, you then hold the amg button and it saves your settings.
Old Sep 19, 2015 | 03:21 PM
HPMan's Avatar
2014 E63 S
There is no such thing as an "AMG Mode" on these cars. As Mixedfruits noted, the AMG button is merely a memory button to store whatever settings you want.
Old Sep 19, 2015 | 08:59 PM
PeterUbers's Avatar
In the AMG menu, select your suspension and transmission mode and then each time you press the AMG but moving forward you will achieve these settings. Somehow you set the comfort mode suspension and transmission to the AMG menu.
Old Sep 19, 2015 | 10:24 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
+ 1
Old Sep 21, 2015 | 11:51 AM
BrabusNYC's Avatar
2014 E63S
+1
Old Feb 22, 2019 | 10:04 PM
KravDieselAMG's Avatar
2014 e63 amg s
old thread, but you guys are the best!!
