Stock M157 resonator
I cut mine out last year and loved the sound. However I am thinking of going with a turbo back downpipe (yes hind sight.....) and I want it back. Please if you have one you do not want or are about to cut yours out, do not discard of it, PM me and lets work out a deal.
kponti (03-16-2016)
PLATINUM SPONSOR
Since both of you have looked inside your resonator, can you tell me if it has a crossover inside it or X pipe configuration? I don`t see any exhaust balancing and thought it might be inside the resonator.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Couldn't see a whole lot, but it looked like it was a tiny H-pipe connection (like a 2 inch connection). It has been a while so my memory may be quite off lol
That's exactly right. Its mostly straight pipes with a tiny Maybe 1 inch diameter balance pipe between them right at the entry.
