m157 engine damaged
m157 engine damaged
i was racing sadnly the is smoke coming from my engine i stopped the car and shout the engine off an open the hood and the was fire from the right side of the engine i was the fire exhoungher thank god it was small fire there was oil every where on the right side of the engine
i toke the car to a machine and he cleaned the engine bay and found one of the spark plugs was broken
and we started the engine the engine run smooth but a lot of smoke came out the exhaust like hell
we don't know from where it is coming from
did this happen to any one before
https://www.youtube.com/watch?v=29GS...ature=youtu.be
Received 2,162 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
What is the year and the mileage of the M157 engine, was it maintained well, was it abused, is this car something you bought brand-new and don't know the previous service history? Does the car have a tune on it? Your first post is extremely lacking in very important details
screw991le (05-17-2016)
Blown turbo seal sounds more like it
PLATINUM SPONSOR
Do a leakdown test.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Could be my eyes, but it looks like the ground strap cooked off the plug - this usually happens due to intense heat. What tune is running on the car? Are they one-step colder than stock plugs?
I'd agree with KLR_CLS above, if you say the engine is smooth, then the cylinder should be ok. That much smoke with a damaged piston/cylinder would be audible to a degree.
I feel for you man. Hope you manage to get it sorted with minimal fuss.
The shop doesn't had Smail cam
So tomorrow we will do a compression test and also we change the spark plugs and we will run the car and then we remove the plug I wish I don't see oil on it
