M157 misfire
Move the coil also to a different cyl. Now number 5 would have a different coil/plug and only the injector will remain. If the misfire move to a different cyl you will know what part is bad Coil or Plug.
I do this this all the time to save from not replacing plugs and coils as I service car on the side for fun and to save my customer $.
In this case if it is the plug a fresh set would be installed.
If it is a coil you can install a single new coil but be sure the other 7 will soon start to fail.
