Front Caliper bolts 2014 63s
2014 E63s 1993 mazda rx7 on Boost
Hello All.....Can I remove these with the car on stands or does the car need to be on a lift with a 4' breaker bar to loosen those bolts.
Reason I am asking such a question is that on my 211 63 the rear caliper bolts need a 4' bar and a 2' pipe car on a lift to crack those caliper bolts....
Doing rotors and pads and also removing my backing plate to refinish...
I am hoping this is a driveway special..
Side note: Is any running Akebono pads if so what is the PN.
Thank You All...
Thank You All...
Thank You All...
Thank You All...
DAM ME..
I need to remove rotor so I need to remove the caliper bracket.
The bolts that holds the bracket to the spindle is what I had issues with on my 211 rears bolts. First time I am doing a W212 front rotor removal and was wondering about those bolts. I also need to remove backing plate to paint...or replace..full of rush.
E63s
I usually remove them with a 30" snap on ratcheting bar, no special pipe needed. I might be a tad bigger/stronger than you though.
They torque in there pretty tight and have thread locking compound on them, if you can squeeze an impact gun in there, do it. Use a quality impact swivel if needed.
Replace the bolts every time, as per WIS.
