LSD install on non LSD car (2013 E63 P030)
Thanks, looking forward to taking advantage of the resources here and adding information whenever I can.
LSD had totally transformed my previous AMG.
Maybe I'm the exception instead of the rule...???
If you want to do the swap and can get another diff housing built up with the LSD before hand it's probably a quick R&R.
If not then this will take more time and more care as you'll need to make sure all the normal things in a gear install are taken care of such as pinion spacing, bearing preload, and checking/setting backlash. Not something where you just yank the open carrier and install the LSD carrier and call it done.
Are you doing this yourself or going to hire a shop?
-chris
-chris
