2014 e63 stage one eurocharged dyno
Going for a re dyno to see what my stage 2 catless downpipes is putting down so I figured I'd post my stage 1 numbers first . This was done on a dynocomp 84degrees. Yes I do realize some dynoes put down more then others so I don't know where this dyno stands as cr as numbers but this is what it.
589whp highest tq was 643. Btw the green pull was with pre turbo meth injection. It shows that the pre injection definitely is doing its job and keeping runs consistent plus I gained an extra 14hp with it. The tq numbers were slightly less, but as you can see it slightly gained more tq towards the end of my power band compared to the first tq run. I was happy to see my injection is working.. p.s the black lines where a test run not a full power run
CerBErusM113 (09-25-2017)
Dyno video
Isn't the greatest but it will do. Sounds much better with cats out
CerBErusM113 (10-06-2017)
Great results with the pre turbo meth injection and thank you for posting! It really sheds some light on that debate. Your car not being tuned for it works out well. Anxious to see the results of your stage 2. My buddy just went to their stage 2 and off road dps. We are dynoing next week but the car feels like a beast!
Stage 2 is a tune that eurocharged has . When you remove your cats and add a turbo back downpipe. You send the ecu in so they can retune for the upgrades. THAt dyno graph was stage one. Meaning ecu upgrade with no other mods, stock dp stock intake system
So I assume the black lines in your dyno plot are the stock baseline for your car without a tune? If so, incredible gains over stock. As you said some dyno's are more customer pleasing than others but if you dyno on the same one it'll be interesting to see what your next tune nets you percent-wise. Keep us informed.
