A1 service cost for E63?
E63 SL55 996TT C5Z06
just realized i'm 10 days past due on the A1 service for my 2015 with 20k miles on it.
whats approximately does the dealer charge for A1 on these cars? thanks
jvakos (10-10-2017)
I would suggest going to an indy instead of dealerships. If you don't mind driving to Palatine for indy, I would recommend Marcin at Speedriven.
I just had the same service done at MB Foothill Ranch in So Cal and it came to $219 before applying the coupon I received from them. Check the website for the dealer of your choice for service specials. There was a $50 off coupon on the MBFR site. If all else fails, Costco also has a preferred dealer network and I believe it's good for 20% off service and parts. Good luck!
Received 1,467 Likes
Service A is typically in the $300 range, but as others said, it can vary from dealer to dealer as some offer discounts and others may match or not. Also not sure if you have time to use this $100 off $200 service coupon. It expires on Oct 15th. Sometimes you can call up MB and ask them to extended it if you can't get an appointment til afterwards.
https://www.mbusa.com/mercedes/service_special/fb2017
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
Here is an SL550 with ABC in Minnetonka, MN, 2016 model with 17K miles; might be worth a look: https://www.mbusa.com/en/cpo/invento...9277?zip=37069
