Jacking up rearend
Jacking up rearend
Is there a safe spot to jack up the rear end? The rear diff looks like it could work, but I’m hesitant to try it and damage the cooling fins
Yes, jack up on the differential which is in front of the cooling fins. Do not jack up from under the cooling fins as you had said.
