0-100 mph Times, Stock and Tuned
Do you guys know what range the 0-100 mph times shoud be? tuned versus stock?
I just had the VBOX tell me I hit another 3.3 0-60 but I only hit 100 at 7.8 during the same run. 7.8 seems off to me. 4.5 seconds to get from 60-100? I was floored the whole run in S+. It felt like I was moving pretty good. I actually never did a 0-100 before the tune. I can I guess by just swapping my ECU's. Is this 7.8 time jacked up? I never really followed this parameter much. I realize that drag is a squared function of velocity. But these cars don't have a lot of drag. Just seems slow to me. But I don't know for sure. |
We know our cars don’t launch well but they also lose a lot between 1-2 and 2-3 shifts so I’m not surprised. |
That's stock 2014 E63S on the right column, motortrend e63S vs 2014 M5 cp (left column) ... great article and video you need to take that car to the track vrod the stock e63S is 8.0 to 100mph so not too far off your pace but 0.2 seconds is about a car length right at 100mph? also what altitude are you? |
(Post 7457515)
That's stock 2014 E63S on the right column, motortrend e63S vs 2014 M5 cp (left column) ... great article and video you need to take that car to the track vrod the stock e63S is 8.0 to 100mph so not too far off your pace but 0.2 seconds is about a car length right at 100mph? also what altitude are you? The road I was on may not have been flat either. Track would be good. And I am at sea level btw. I may try a couplemore times too. I tried to quit throttle right at the 100 mark on speedo. Maybe I let off a bit early. Another review I found online similar to yours above had a 2012 0-100 at 7.7 and it was stock. So that had me concerned until I saw your post. |
OK, Now Things Make Sense!!!
Well Guys,
I found the perfect very low traffic section on a 4 lane expressway to do my runs. It might be just a bit too short though for a full 1/4 mile run. I was able to get these nice times though yesterday afternoon with the following parameters: Traction off AC off Windows up S+ mode all the way Suspension at double bars 3k rpm brake boost tires at standard pressure no passengers With these settings I was able to spin all 4 wheels for the first time for about 1/2 to 1 second (quite audible) and still got these numbers: https://cimg1.ibsrv.net/gimg/www.mbw...967c93dcb7.jpg https://cimg0.ibsrv.net/gimg/www.mbw...6c40d7117a.jpg Turns out the 2017 Hellcat does 0-100 in 7.2. So it looks like I'm in some good company. The AMS tune is VERY REAL GENTLEMEN! |
And there ya go ... those are 2018 e63S numbers .... well done |
I did 0-100 in 7.206 my eurocharged tune is .2 Quicker to a 100 :o |
How were you able to brake boost so high? When I try with all the parameters you said, I can’t get it to launch any higher than like 2,300 and that’s with my left foot hard on the brake and my right foot to the floor. My fastest times are still using Race Start |
The highest rpm I been able to launch via brake boost is 22-2300 rpm also |
Originally Posted by g60wall
(Post 7459503)
I did 0-100 in 7.206 my eurocharged tune is .2 Quicker to a 100 :o FYI I have a Eurocharged tune on my 2011 through the OBD port. I know they make good stuff. However, they badly dropped the ball on me when the flashing stopped working and I have been stuck with stock profile. I tried more than once, even sent them a youtube video showing them how it was not working properly anymore. Someone ther named Solomon said they would straighten in out. Then they went quiet. So I went with AMS this time. Both reputable tunes. However, the follow up customer service from them didn't sit well with me. And I don't care a lot about the 2011 tune problem as I am selling her to some VERY LUCKY person and if selling it should be stock anyway. Enjoy your fast car! |
Originally Posted by Boostaddict
(Post 7459532)
How were you able to brake boost so high? When I try with all the parameters you said, I can’t get it to launch any higher than like 2,300 and that’s with my left foot hard on the brake and my right foot to the floor. My fastest times are still using Race Start This is the best answer I have fellas. Cheers. |
A tuned W212 E63 will be faster most of the time than a stock very strong W213 E63s. However, most of those gains by the W212 will be seen more on a rolling race than from a standstill. There are cars at 4000+lbs with less power that can outrun all our cars from 0-60mph due to awesome launches.
The 70/30 fixed split AWD will always be slower than a variable AWD system from a dig (HP and weight being reasonably close). The W213 has had the launch/TCU algorithm improved over the W212, so goes to show it can launch better than a tuned AWD W212. All this to mean if you can launch anywhere near as well as the W213 with your tuned W212, you will quickly reel it in and pass it up well before the 1/8th mile. Gets worse for the W213 on a roll. Also, a tuned W213 is not showing to be significantly more powerful than the tuned W212 (W213 has ~20 WHP more but some 50-50 WTQ less except with Eurocharged tune). Only one vendor has shown power and track times that is in the mid-10s. Most are in the high 10s (like the tuned W212s). The W213 is the dream car (between the two) to leave stock cos there is little to be gained from tuning it as far as raw track times go. Now let us compare to the competition.....RS7 are not running much faster, but they can certainly out launch either AMGs. M5s will be the ones to watch..... too new to tell right now |
Originally Posted by kponti
(Post 7459896)
The 70/30 fixed split AWD will always be slower than a variable AWD system from a dig (HP and weight being reasonably close). The W213 has had the launch/TCU algorithm improved over the W212, so goes to show it can launch better than a tuned AWD W212. All this to mean if you can launch anywhere near as well as the W213 with your tuned W212, you will quickly reel it in and pass it up well before the 1/8th mile. Gets worse for the W213 on a roll. Also, a tuned W213 is not showing to be significantly more powerful than the tuned W212 (W213 has ~20 WHP more but some 50-50 WTQ less except with Eurocharged tune). Only one vendor has shown power and track times that is in the mid-10s. Most are in the high 10s (like the tuned W212s). The W213 is the dream car (between the two) to leave stock cos there is little to be gained from tuning it as far as raw track times go. Now let us compare to the competition.....RS7 are not running much faster, but they can certainly out launch either AMGs. M5s will be the ones to watch..... too new to tell right now I enjoyed reading your post. Thanks a lot. If everything you say is accurate, I am feeling pretty good with my decision to buy the 2015 and tune it versus buying the 2018. Also, I was just having difficulty with a 4 litre motor. I am a bit more old school that really believes in no replacement for displacement. Also based on the displacement, I felt the gains from tuning would be reduced in that motor vs the M157. Stuttgart is already getting a cr*p load of power out of that 4.0 litre. Again if you are on point here, you confirmed my assumptions. Cheers! |
The m157 will never compete with the new 4.0. Tune only 18 e63 are going mid tens. The motor has a hot v configuration, nano coated cylinder walls etc etc etc. turbo upgrades would take a few hours. Should be way easier to work on. I also have a w212 e63s but there no illusion in any form that my car is better than the latest edition. |
(Post 7460412)
(Post 7460412)
Tune only 18 e63 are going mid tens.... |
Originally Posted by chiromikey
(Post 7460765)
Well, ONE tune only W213 E63 went mid tens. But if you will recall tuners pulled the same crap with the W212 with their one off mid 10 claims that were never able to be duplicated by any customers.
My tune only eurocharged w212 went 11.07, I broke the world record with my eurocharged S65. I have no reason not to believe there claims. I would double down and say they will get a few more .1 off there time in the next two years in complete stock trim. |
In regards to the mct, I think a physical limitation on the driving experience they can provide has been reached and they will always be somewhat different in comparison to a true automatic |
‘14E63 S Eurocharged tune, Speedriven catted downpipes on a 2% decline on a freezing winter morning with soft launch off idle (roads had salt)https://cimg7.ibsrv.net/gimg/www.mbw...67a0b51d3.jpeg |
Getting ams dyno tune this week ... will post Pre and post dynos i don't have the vbox but I'll get one |
(Post 7469681)
Getting ams dyno tune this week ... will post Pre and post dynos i don't have the vbox but I'll get one I am told by FFTEC ( an AMS partner out here in the Bay Area) that you can't really do a pre and post dyno the same day. They suggest to me that I bring the car in with the tuned ECU first do the 5 pulls for $150. and then come back a different day after getting at least one full "drive cycle" on the original ECU. They say that the numbers will not be correct if the ECU has not registered some minimum amount of time being driven. My thinking was that they are just trying to get paid twice. But after looking a bit more into it, it sounds legit. The extra $150 to run the stock ECU isn't that big of a deal. But the 35 mile drive and time there is a bit of a headache. Ugh. But I am scheduled to at least get the tuned ecu dyno'd in a few weeks! I will post results after I get them. Side note: I am scheduled to take the car in to the dealer for some minor warranty fixes tomorrow so I put the stock ecu back in it yesterday. There is NO DOUBT that the tuned ecu is way more powerful! Car feels slow now. lol |
Originally Posted by Vrodman
(Post 7457406)
Originally Posted by TMC M5
(Post 7469546)
