MRG Ti Studs
MRG Ti Studs
First off, Happy Father's Day to all!
Have been sitting on these since November . Threw the summer shoes on and didn't want to do this at the same time just to make sure the upgraded (in size) wheel/tire combo was not rubbing or making weird noises (this way it'd be easier to isolate the source of any possible noise). Anyhow.
Some simple iPhone pics (I apologize for the giant pics. I'll try to remember to choose "medium": next time):
So far, I am pretty happy with how they look. This is my first Euro car and I had never dealt with wheel bolts before. My brother used to drive an M3 and I used to see him sorta struggle changing his wheels; So, the first aftermarket accessory I bought for this car was this set of studs. Now, having dealt with the bolts and spacers and NOW these studs with the same spacers... I think that it was somewhat easier to mount the wheels without the studs, even when dealing with spacers (which in my case they are just 3mm). On a slightly different note; I did notice, the first time I pulled the OEM wheels off, that some of the wheel bolts were pretty loose and some were pretty tight. I will chalk that one up to the "oh so great" mechanics at the dealership I picked up the car from. I personally torqued the summer wheels down to 100 lb/ft with OE wheel bolts about a month ago. Today, when taking them off, they didn't seem THAT tight (but at least they all felt to be at the same tightness). Are wheel bolts more prone to loosening up? I don't recall ever experiencing this sorta thing before.
Bonus info (lol): Wheel woolies don't fit between the front rotor and the wheel (19")... so, don't waste your $.
T_Cob (06-18-2018)
Thanks. I like them so far. These are 19x9.5 and 19x10.5.
CerBErusM113 (06-19-2018)
torque
These I believe are the 75mm. The shorter ones. I think they are good for up o 10mm spacers.
One thing I neglected to mention was... while mounting the driver's side wheel back on... the damn thing kinda got jammed a lil' (the wheel went in a bit slanted) and the thread on one of the studs got slightly damaged. Material came off. I carefully threaded the nut on and took it off. Made sure there was no metal filings and did final torquing. So... these aren't very tough. As for additional shots... I will have to see what else I have on my phone. Will update later tonight.
You may want to research galvanic corrosion between titanium and steel (wheel hub). Also, these titanium wheel studs are mostly for show. Take a look over on Bimmerpost if you want more in-depth analysis, and reported failures on titanium studs in general. The kit looks awesome, but I personally wouldn’t run it.
Thanks. I used blue loctite. Will re-torque in a week or so
Figured I'd paste this link since this thread over at Bimmerpost as it is only a couple days old. Post #4 is the most important.
http://f80.bimmerpost.com/forums/sho....php?t=1510538
