Dyno result
Old 04-03-2019, 10:54 PM
PIRATE1's Avatar
C63 507 SEDAN
Dyno result
Hello guys
just coming back from dyno I want to share with you my result
i don’t know if is good are not but here the result on a mustang dyno!
This is with 94 oct
i try to load a 100 oct map with my genius but i don’t know why the map want load? Always a error!
How many percent to know how much at the engine?
also mod was tune by OETUNNING stage 2 ( cat delete and filter ) stock exhaust
Old 04-04-2019, 10:35 AM
Savage212's Avatar
2014 E63 AMG wagon
Originally Posted by PIRATE1
Hello guys
This is with 94 oct
Wow looks great!
Old 04-05-2019, 12:38 AM
PeterUbers's Avatar
Received 2,162 Likes on 1,520 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
How does it perform on the track?
dyno is just a graph ... is this sae corrected? What type of dyno is this? Dyno jet? Mustang?
historically you divide your torque and horsepower numbers by 0.83 and that is what is approximately at the crank. This reflects a generally accepted 17% drivetrain loss for the 2014 e63 4 Matic system:
Old 04-05-2019, 06:43 AM
PIRATE1's Avatar
C63 507 SEDAN
yes sae corrected
and dyno mustang
my question is the hp wheel seem to be low compare to my wtq
eric
Old 04-05-2019, 10:10 AM
1MavRick's Avatar
CLS 63 and M4
yes sae corrected
and dyno mustang
eric
your hp is always going to be low compared to tq in these cars. Full boost at low rpm’s + big V8 = gobs of twist. About the only way to get the hp to be somewhat commensurate is to get bigger/more efficient turbos. But it’ll still be a challenge.
Old 04-05-2019, 10:15 AM
PIRATE1's Avatar
C63 507 SEDAN
But my question is those number are pretty much spot on on a mustang dyno with the mod I have ?
because everyone seem to have more than 600hp at the wheel
thank in advance
eric
Old 04-05-2019, 10:21 AM
1MavRick's Avatar
CLS 63 and M4
thank in advance
eric
dont know if it’s still like this but, Mustang dynos used to be called ‘Heartbreakers’. They were notorious for reading considerably lower than Dynojets. Are you comparing them to other Mustang’s. And...even then...weather and calibrations can cause variances. Take her to a track and see what she traps. THAT is a pretty good indication of any mod increases.
Old 04-05-2019, 10:41 AM
PIRATE1's Avatar
C63 507 SEDAN
11 flat 128 mph
I.T. Guy (04-05-2019)
Old 04-05-2019, 12:18 PM
1MavRick's Avatar
CLS 63 and M4
11 flat 128 mph
yeah...thats the dyno. i wouldnt sweat it. your car is running STRONG!
Old 04-05-2019, 12:23 PM
PIRATE1's Avatar
C63 507 SEDAN
thank
Old 04-05-2019, 01:53 PM
I.T. Guy's Avatar
Received 1,199 Likes on 631 Posts
2023 E63S Wagon
128 is great.
Even rhymes
Old 04-05-2019, 02:05 PM
PeterUbers's Avatar
11 flat 128 mph
Timeslip please
Old 04-10-2019, 12:13 PM
Amg63-'s Avatar
CLS63 AMG
So basically on stock turbos tuned t stage 2 (maxed out, basically) , does the car feel like it runs out of steam as speeds climb due to the HP being much lower than the TQ?
Old 04-10-2019, 12:17 PM
Amg63-'s Avatar
CLS63 AMG
Timeslip please
Thats the same exact time that the EC stage 2 tune+catless dp+air filter ran in the other thread with timeslips of 11.0@128mph. I forgot which thread it was where were speaking of it,
Old 04-10-2019, 01:36 PM
PIRATE1's Avatar
C63 507 SEDAN
Timeslip please
sorry don’t have the time slip because still winter here
I just make this pass with my DRAGGY
and no traction at all with my winter tire
i just delete the 11 flat @ 128 mph but as soon as I put my summer tire I will put the new result ! But is not bad for a 560 whp
Amg63- (04-10-2019)
Old 04-10-2019, 01:44 PM
Amg63-'s Avatar
CLS63 AMG
are you tune only car?
Old 04-10-2019, 01:57 PM
PIRATE1's Avatar
C63 507 SEDAN
tune stage 2 only plus took off the cat
eric
Old 04-10-2019, 02:07 PM
Amg63-'s Avatar
CLS63 AMG
eric
So your tuned with catless pipes?
Should be making over 600whp with those mods
Old 04-10-2019, 02:28 PM
PIRATE1's Avatar
C63 507 SEDAN
no only 560whp on a mustang dyno and 746 wtq
Old 04-10-2019, 03:51 PM
PeterUbers's Avatar
Too bad you deleted that 11.0 @ 128 --- that's on winter tires? And you ran uphill at 0.27% slope? That would be a very nice run.. the difference between 11.22 and 11.0 is significant.
Either way, your engine is running strong I wouldn't worry about that whp number.
Old 04-10-2019, 04:06 PM
PIRATE1's Avatar
C63 507 SEDAN
i will check at home maybe I have it on my iPad
its 11.01 at 128.1
eric
Old 04-10-2019, 05:12 PM
Amg63-'s Avatar
CLS63 AMG
its funny how the w212 e63 on stage 2 is running exact same times as w213.
We we were just discussing in another thread results of EC stage 2 tune which ran exactly 11.0@128, time slips ad all posted there.
Old 04-10-2019, 05:14 PM
Amg63-'s Avatar
CLS63 AMG
the mustang dyno explains it as they read significantly lower than a dynojet. Similar to the w212 on a dynojet your stage 2 w213 would likely dyno at around 600+whp and 750+ wtq.
PIRATE1's Avatar
C63 507 SEDAN
you mean w213 stage 2 run 11 flat also or stock w213
Old 04-10-2019, 05:18 PM
Amg63-'s Avatar
CLS63 AMG
no I mean stage 2 w212. Based of your results it looks like stage 2 w213 also doing 11.0 but I’m sure it’s got 10s in there.
Quick Reply: Dyno result
