100k miles, maintenance aside from regular schedule?
Old Feb 9, 2020 | 06:27 PM
Lfntms's Avatar
212 E63s
My 212.2 M157 is about to hit 100k. It’s been serviced at the local MB dealership every 10k like clockwork. I’d like to see if she’ll make it to 200k. Would you recommend anything aside from the regular maintenance schedule? I recently replaced a crank position sensor that was leaking, did the driveline at 60k as well as the plugs.
Old Feb 9, 2020 | 07:57 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Service Manual
File Type: pdf
Old Feb 10, 2020 | 12:05 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
-5k mile oil/filter change intervals
-Change all diff fluids
-Check cam adjuster magnets and position sensors for oil contamination. Replace as necessary
Old Feb 10, 2020 | 09:54 AM
5soko's Avatar
AMG
+1
normal 100K mile things like other cars
02 sensors
belts
trans fluid and filter
diff fluid
brake fluid
i would do Spark plugs coils if never done
engine and trans mounts
If you wanna go further:
water pump and thermo
turbo plastic coolant lines
Old Feb 10, 2020 | 11:08 AM
PeterUbers's Avatar
https://mbworld.org/forums/w212-amg/...-w212-e63.html
