Clutch slip in low rpm/high gear/high load scenario (with tune)
This does NOT happen when I flash back to stock programming (solid connection the entire time).
Any ideas why this is happening? Too much torque so TCU decides to disengage a bit to protect itself? Or is the torque so high it's literally creating slip mechanically? I really hope not the latter.
Tune is stage 1, theoretically ~660hp/740ftlb at the crank.
Other items to go down the list for trans would be, trans fluid change/level check, full re-adapation of the trans via benz STAR program/computer.
