PLM Heat Exchanger Upgrade - Group buy!!!
Old May 7, 2020 | 02:18 PM
  #76
1MavRick's Avatar
CLS 63 and M4
Originally Posted by karpetcm
just checked mine again its all bad not only are the welds not all that great but there are bunch of aluminum shards coming out thats why it rattles for some.
F CKIN YIKES!!!
Old May 7, 2020 | 02:36 PM
  #77
Marine 1's Avatar
2014 AMG E63S
Originally Posted by 1MavRick
F CKIN YIKES!!!
hey bud reach out and send it back maybe just a one off!!
They seems pretty reputable and should honor your request.
Thx
Old May 7, 2020 | 02:41 PM
  #78
Marine 1's Avatar
2014 AMG E63S
Originally Posted by WANTED!!
Given the amount of issues I showed you, and the few I didn't (places where the aluminum was clearly not cleaned prior to welding, and the cold welds clearly ground down), I highly doubt an exchange would yield a better quality product. The end tanks being off by 3/10ths of an inch ought to serve as a strong indicator.
I'm either going to return it or call it a $400 mistake. Given the amount I spend on parts in a month, I can take the loss.
The decision is yours and I would be highly pissed to not trying to give bad advice. Plus it's your dime and the bad experience to match. Call them and request a full refund.
Thx
Old May 7, 2020 | 02:45 PM
  #79
karpetcm's Avatar
2006 E55 AMG
Talked to Frank he apologized issued a return label. Once he gets it ill get the refund.
Old May 8, 2020 | 03:39 PM
  #80
maxusa's Avatar
2013 E63 P30, 2010 GL550
My unit has arrived. It shows no problems described earlier by @karpetcm. My unit is straight, welds looks good, fins look good, and no rattling inside the unit. A few aluminum shavings fell out of the core fins, but they get caught in the exterior during manufacturing. This happens if you bang the unit on wood - small debris may fall out. The important point is these aluminum shards are caught in the fins, not inside the unit. I put air and ran water through it - appears sealed. My heat exchanger is ready for installation. Hope this helps.
Old May 8, 2020 | 03:47 PM
  #81
BCP's Avatar
BCP
2014 E63s
Received mine today and all appears to be well. Nothing rattling inside and violently shaking it for several minutes resulted in two small shards of aluminum. Sucks some received a vastly different product, but hopefully PLM makes it right on a satisfactory manner.
Old May 8, 2020 | 06:30 PM
  #82
NoVAe63s's Avatar
2016 E63s
Bigger isn’t always better, has anyone checked the flow rate and returning water temp?
There’s a bit of engineering that goes into heat exchangers (of all types not just for cars) and while this part looks big and pretty, I’m interested to hear what the actual change in air temps are.
And does HP Tuner have a data point for the IAT? We could answer the question if someone want to let me borrow their IC!
Old May 8, 2020 | 06:37 PM
  #83
Siegmann's Avatar
10-second E550
HPT does record IAT. I'll try to get a comparison under similar conditions.
Old May 8, 2020 | 07:47 PM
  #84
Yakatak's Avatar
2016 E63 S AMG Wagon
Before I contact PLM, can anyone confirm that this unit will serve for both of the exchangers on a E63S AMG? MB shows 2 different part numbers. ??
Old May 8, 2020 | 09:01 PM
  #85
maxusa's Avatar
Yes, I can confirm in EPC that 2014+ W212 E63S has 2 heat exchangers, both the same part number A0995003203. Also, if I recall correctly PLM stated they sold out, but VRP stated they nearly matched group buy. Best of luck. Hope this helps.
Old Oct 16, 2020 | 04:19 PM
  #86
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
Just recieved our shipment of 50 more of these if anyone is looking!
We have been Guaranteed no manufacture defects
https://www.vrpspeed.com/product/aux...nger-groupbuy/
Old Oct 24, 2020 | 01:03 AM
  #87
RichieAustin's Avatar
2004 E55 Amg
could we do another group buy lol
Old Oct 26, 2020 | 03:07 PM
  #88
SPONSOR
E55 C63
We have them on a significant sale right now, Check the link above
Old Apr 5, 2021 | 06:37 PM
  #89
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Any feedback from those who installed these?
Old Apr 7, 2021 | 01:45 PM
  #90
SPONSOR
E55 C63
We have sold over 80 units, with no complaints, The issues here were from PLMs first batch. Those issues have been resolved
Old May 24, 2021 | 04:41 PM
  #91
PhuongNguyen's Avatar
2013 E550 coupe
Install
Is it pretty easy to install?
Old May 24, 2021 | 05:34 PM
  #92
SPONSOR
E55 C63
Very Easy to install
Old May 24, 2021 | 05:40 PM
  #93
2013 E550 coupe
the system purges itself?
Old Aug 21, 2021 | 01:47 AM
  #94
PekkaH's Avatar
2015 CLS550 Shooting brake 4-matic
Did anyone ever measure IAT before and after installing this heat exchanger or some other model like Alpha, or wagnertuning? Any benefits ?
Old Aug 23, 2021 | 09:41 PM
  #95
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
AMS version of the aux heat-exchanger, if anyone is curious. Some bent fins but looks good otherwise, holds pressure. And no metal pieces inside lol
Old Aug 24, 2021 | 08:32 AM
  #96
PekkaH's Avatar
It looks like a really good quality! Nice piece. Did you measure IAT before/after? Or is it connected to main engine water cooling system and you don't know? I did install original AMG extra heat exchanger to my IC system like S AMG models and it did add about 0,5l liquid on system and get temps down a bit. This Alpha is 38% bigger than original AMG (according to their website), so the benefit maybe not so big if any att all?
Old Aug 24, 2021 | 12:10 PM
  #97
timm206's Avatar
I haven’t installed it yet, but once i do i will do some pulls and see what the peak iat’s will be for each.
Old Aug 24, 2021 | 02:47 PM
  #98
PekkaH's Avatar
Yes nice, that is really interesting to see then.
Old Aug 25, 2021 | 04:28 AM
  #99
SAMzE63s's Avatar
E63s
the “a” looks awesome once installed. I’m tempted to get these if i don’t get an interchiller
Old Aug 25, 2021 | 07:20 AM
  #100
timm206's Avatar
It does look good, unfortunately for the driver side implementation the logo has to be upside down.
