B1 Service? Can I do a DIY?
Old Aug 31, 2020 | 11:49 AM
Mikesoja's Avatar
2014 E63s AMG
Hey Guys my B1 Service notification came up on my E63s saying I got 1400kms until its due. So I called up my tuner to ask if he can do it and he said yes.. but it consists of a bunch of things I don't think need to be replaced? Here's the list he gave me:
1. oil change $150
2. Spark Plugs $500
3. Belt Install ? $200
4. Cabin FIlter $120
5. Air Filters $150
Total $1120 but hew said he'll do it for $900
What do you guys think? and I got a feeling some of these items are easy DIY tasks and for one I can do my own oil changes and have done so. I think air filters and cabin filters should be easy as well. Spark plugs not so much but I do have a Spark Plug changing kit from Princess Auto that I have never used... maybe its time.. but let me know what you guys think.
Old Aug 31, 2020 | 08:25 PM
ygmn's Avatar
2015 E400 Sedan
ouch...........
expensive and what does manual say is due at your odometer reading?
Old Aug 31, 2020 | 10:12 PM
Rehabguy's Avatar
E63S
Refer to post #8. https://mbworld.org/forums/m-class-w...r-filters.html
You can DL maintenance booklet pdf. Many services are mileage related. Oil changes are a definite at least once a year even if car is not driven (oil brakes down). Air and cabin filters are simple enough DIYs.
Old Sep 1, 2020 | 08:33 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
How many miles is suggested for new spark plugs? Thanks
Old Sep 1, 2020 | 04:57 PM
MerchantM5arine's Avatar
2014 E63 S Wagon
IIRC plugs should be done every 60K according to MB.
I did my plugs recently (115,000 miles) and the job wasn't too bad, although 2 things that made it much easier for me...
1. Have the right spark plug tool... It made the job go by much faster (I actually started doing plugs without it). Hazet looks to be the same as the MB branded one in my opinion.
https://www.amazon.com/Hazet-4766-3-wrench-hinged-design/dp/B014R5SHO4/ref=sr_1_39?dchild=1&keywords=mercedes+spark+plug+removal+tool&qid=1598993055&sr=8-39 https://www.amazon.com/Hazet-4766-3-wrench-hinged-design/dp/B014R5SHO4/ref=sr_1_39?dchild=1&keywords=mercedes+spark+plug+removal+tool&qid=1598993055&sr=8-39
https://www.amazon.com/Mercedes-Benz-Genuine-Wrench-278-589-00-09-00/dp/B07H3F3ZB5/ref=pd_sbs_60_2/142-3446614-3096529?_encoding=UTF8&pd_rd_i=B07H3F3ZB5&pd_rd_r=4fd9cb04-caee-4a7f-a689-673cc6d2c911&pd_rd_w=yTxJ6&pd_rd_wg=XwKvp&pf_rd_p=703f3758-d945-4136-8df6-a43d19d750d1&pf_rd_r=SB3W5K73NV047AB8X7JQ&psc=1&refRID=SB3W5K73NV047AB8X7JQ https://www.amazon.com/Mercedes-Benz-Genuine-Wrench-278-589-00-09-00/dp/B07H3F3ZB5/ref=pd_sbs_60_2/142-3446614-3096529?_encoding=UTF8&pd_rd_i=B07H3F3ZB5&pd_rd_r=4fd9cb04-caee-4a7f-a689-673cc6d2c911&pd_rd_w=yTxJ6&pd_rd_wg=XwKvp&pf_rd_p=703f3758-d945-4136-8df6-a43d19d750d1&pf_rd_r=SB3W5K73NV047AB8X7JQ&psc=1&refRID=SB3W5K73NV047AB8X7JQ
2. The plug leads are on.... t.i.g.h.t. Buy at least a couple plug leads. I was lucky, the previous owner of my car used dielectric grease so my leads came off easy... YMMV.
GL,
- Matt
Old Sep 2, 2020 | 10:14 AM
FastWgn's Avatar
2016 E63 Wagon
Echo what Merchant is stating above - I started trying to do the sparkplugs and gave up. The coils were on so freaking hard I was afraid to break things. I did however try to do it cold.
I think having the engine warm (maybe even hot) is key. But that makes for a less fun experience. Since I'm still under warranty I went to dealer and overpaid.
Old Sep 4, 2020 | 08:44 PM
Mhoughland's Avatar
2105 e63s
B1 is probably just oil change and air filters and inspection. Plugs aren’t due til 60k and belt should go 100. When you do the belt I would recommend the belly kit with new idlers and tensioner. Mercedes pulleys seem to like to squeak after belt work
Old Sep 5, 2020 | 12:35 PM
PeterUbers's Avatar
A tuned engine needs plugs every 10k miles
i have a DIY on coils that's super easy, engine needs to be at 100F at least
plugs need to be perfectly indexed
you asked your "tuner" so that is to say you're tuned
Old Sep 5, 2020 | 12:38 PM
PeterUbers's Avatar
https://mbworld.org/forums/w212-amg/...ml#post8073603
