Analysis Help - HPTuners Data - Stage 2 Wagon
I've got a 2014 E63S Wagon with a Stage 2 ECU tune from Jerry at EC. I've been running it for a little while and have noticed that the car seems to go through multiple modes of behavior - I've searched to see if others have had similar issues and I cannot find any reports, so I'm getting the sense it is unique to my situation. I'm big into data (looks like I'll be at home on this forum) and excited that this presents the opportunity to get to know my vehicle a bit better. I've gone ahead and purchased the HPTuners MPVI2 and had my first go at pulling some long logs today. Following in the footsteps of 5Soko and Brutus I've taking the data and thrown it in datazap.me to make it a bit easier to manipulate. Note that the car is all stock minus the tune.
Key differences in behavior that I've noted on occasion:
- Car will suddenly feel "bogged" and any throttle inputs elicit a sluggish response
- The burble aspect of the tune will go crazy - nearly any closed throttle on a decline will make non-stop cracks and pops
- The only way I've found to limit this is to keep the throttle partially open or to get on the brakes to slow things down (Leads me to believe this is related to vacuum and/or timing)
- Shifting can be affected - either shifting too early or what I describe as a hesitation when shifting (notably when accelerating in 7th as it drops down to 5th)
- RPMs can hunt on occasion at idle (I've not seen this in the stock profile otherwise I'd suggest this is potentially a sign of a vacuum leak)
As a note - I plan to do two other similar runs in the next week or so to get more data on how my vehicle behaves:
1) With the stock profile loaded back on the ECU
2) With the Stage 2 profile minus the "burble" aspect added (I guess burble comes normal with the Stage 2, but I've asked specifically to remove it)
Any feedback/tips/advice would be greatly appreciated!
Some details on max and min:
- Boost
- Max of ~30PSI absolute
- Min of 14.7
- Timing
- Max of ~35
- Min of 19.5
- Intake Pressure
- Max of ~30
- Min of ~3
I did not acquire the car with the tune, just did it over the summer when EC was running a sale.
always a worthwhile endeavor to replace plugs and coils if they haven't been done within 20k miles ... and also what's the quality of your gas?
I've had my stock ecu be rock stable with old coils but then the tuned ecu was very erratic and threw codes until I replaced the coils
Really appreciate the feedback. It's a good point and I'll take this to Jerry and see what feedback he has. Personally, I'm also not totally into the burble. I like the snarl and crack when it happens after WOT, but when it happens all the time and for seemingly no reason it's far less enjoyable. I didn't even realize it came with the Stage 2 until after I had uploaded it and took the car for a spin. Jerry has since provided me with a Stage 2 tune without the burble which I'll have to try and upload.
Is the throttle bogging related to these threads in your sticky? Are you aware of a TSB or anything I can mention to the dealer? https://mbworld.org/forums/w212-amg/...ml#post7750230 https://mbworld.org/forums/w212-amg/...nnoying-5.html
I purchased the car with 19k and the vehicle has just shy of 30k at the moment. I've not changed plugs and the service history I'm aware of doesn't indicate they were ever changed, but that seems like a fairly easy thing to have a go at (I'll reference your coil changing video). As for gas, I'd say normal? It's just 93 from the location station here in NJ. I've noticed this happening regardless of where in the tri-state I fill up.
Once hardware issues are resolved Jerry will set you straight.
however I am on stock gap and stock plugs replaced about 5k miles ago and fresh coils and run my e40 tune, ams 93 tune, and stock tune without issues
As a note - I sent the CSV to Jerry and he is taking a closer look as well. Will report back if he finds anything of interest.
Use of these tools really does help nail down any potential issues, or at least highlight problem areas.
I'm sure Senad will jump into the thread, but I have a general comment.
When logging data, it's important to try and establish a baseline configuration... by that I mean we recommend logging data with TC OFF, in manual mode and logging a full pull in either 3rd or 4th gear. We like fourth just because of the volume of data your acquire, plus it really loads up the fuelling and coolant system, but understand that 130mph pulls can be hard to safely achieve in certain areas. 3rd is a good compromise and doesn't carry the "direct to jail" potential a 130 mph pull on a public highway would entail.
Whenever you are off throttle your timing will be out of whack and not realistic. By just logging a dedicated run, it helps filter out all the spurious data and background noise that gets collected while puttering around.
I suggest doing a run configured as above and then share that data... Jerry will like that a bunch more I promise you.
@brutus_tx Appreciate the welcome and looking forward to contributing. I'm an engineer as well so this sort of troubleshooting is where the goods are at. I'll look to perform the baseline runs and compare the performance of the different profiles as well.
Today's weather was quite fair here with an approximate DA of -370ft
Pull 1
Pull 2
I didn't get chance to run the other tunes so will have to aim to do that another time this week.
- James
What's your timing doing over the same range?
Thats a nice little boost spike at the end of the run as well.
My throttle closures were attributed to the TCU intervening to restrict torque during gear change by forcefully closing the throttle regardless of peddle input. Never during a pull after the gear change.
Look at all the other data points to see if anything looks amiss.. check fueling, timing, knock etc...
I suggest sending this log to Jerry to see what he thinks may be at issue.
Timing doesn't shift at the moment the throttle closes, though obviously I don't know if the timing on a relative scale is normal at all. The only things that show similar dips around the same time are boost pressure and intake pressure.
Appreciate the input.
