car is stuck in sports suspension
Old Nov 23, 2020 | 02:29 AM
Michael Carroll's Avatar
w212 e63s
Hi, my 2016 e 63 is stuck in sports mode. It has 50,000 miles almost on the dot, and one day, I started the car up, and it has been stuck in the sports suspension setting. I at first thought that this was just a little bug and it would go away. However, after a week of driving, it has still not gone away. I still have a service due in a few months and a warranty that will hopefully take care of the issue was hoping that one of you guys may know the diagnosis or tell me what to expect from the dealer. Thanks.
https://imgur.com/a/H7h16TC
Old Nov 23, 2020 | 02:34 AM
maxusa's Avatar
2013 E63 P30, 2010 GL550
Welcome to the forum. Did you try to disconnect the battery? Any error codes?
Old Nov 23, 2020 | 08:58 AM
cotmfk's Avatar
On the shoulder
Very frustrating! Do you happen to have a code scanner (any codes showing up)? At least you have warranty. If there is no quick answer from the forums, I would take it in for repair sooner than later.
Old Nov 23, 2020 | 11:27 AM
PeterUbers's Avatar
Try hitting the amg button you may be a different suspension selected in that page
if you do - then it a button problem
if it doesn't change then it's airmatic fault
Old Nov 25, 2020 | 08:55 AM
MBizzy's Avatar
W212 E63; W204 C350
Happened to me after i installed my lowering springs. Mechanic got out his obd2 reader and found errors
​​​​​ that indicated that they did not fully connect some conectors to the shocks on one side. After connecting it, problem was fixed
