Buzzing Harman Kardon center dash speaker, W212 E63
Old Apr 7, 2021 | 02:42 PM
Blade Canyon's Avatar
2012 E63 AMG
The dealer would not give me a price up front to replace the buzzing Harman Kardon center channel (dash) speaker in my 2012 E63. My favorite Mercedes specialty shop wanted $405 for OEM replacement.
I found these helpful PDFs posted in another forum, removed the display unit (fingernails to removed the plastic trim piece, a small torx bit to remove the display screen), then I was able to reach under the dash and push the pins from below to remove the speaker cover. The speaker itself is not screwed in, you can just grab the anchor points and pull up. There are two wires connected to the speaker. I just disconnected it and put the speaker cover back. I could not tell a very big difference without that 2 inch center channel speaker, so now I'm just motoring with no dash speaker. Still sounds good to me, and no buzzing.
An OEM replacement is $140 from MB direct, part number 212-820-20-02. Maybe I'll order it if I really start to miss that center channel.
https://mbparts.mbusa.com/oem-parts/...ker-2128202002
So here's a question, should my speaker indicate in any way that it is from Harman Kardon? It just has the MB and Logic 7 logos.
ETA: I went back to the CarFax I got when I bought the car. Sure enough the first and only warranty repair on this car was a radio speaker. So, again, should this speaker have been labeled as a Harman/Kardon ? And that dealer just replaced it with MB generic?
File Type: pdf
File Type: pdf
Old Apr 7, 2021 | 02:57 PM
NoVAe63s's Avatar
2016 E63s
Excellent add to the knowledge base! I can only imagine how much the "long wedge" tool costs - probably AMG specific and made by special elves that are paid $1000/hr.
Old Apr 8, 2021 | 09:30 PM
E63_SauceGod's Avatar
2015 E63 AMG-S
My car had this issue as well. I had that crappy speaker replaced at a local shop for like 70 dollars. The replacement wasn't anything special just some random speaker... I don't even notice a difference in sound quality just so much better with that static sound gone.
Old Apr 9, 2021 | 11:52 AM
2012 E63 AMG
Maybe direct sunlight dries out that dash speaker?
Old Apr 12, 2021 | 02:03 PM
2012 E63 AMG
Well I paid MB $140 and installed the new speaker. Hardly any difference in sound, the audio was fine without it. It just bugged me to know there was supposed to be a speaker there.
ETA: The space behind the display panel seems like a good place to hide something...
Old Apr 13, 2021 | 10:28 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
What happens with the center speaker is that sun & heat dries the glue for the surround cone and it seperates creating the buzzing sound. I took mine out, cleaned all the old crusted glue and applied super glue and it has been working fine for more than two years in 50c weather.
Old Apr 13, 2021 | 11:57 AM
2012 E63 AMG
I have reglued speaker cones in my home speakers, but I could not find any separation at all that would explain the buzzing in the center channel speaker I removed.
Old Apr 15, 2021 | 06:50 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
just had the dealer fix my center speaker under CPO warranty that i'm in my last 6 months of. speaker is like $80 bucks from this MB parts wholesaler website and am guessing it was 30 mins of labor max to replace it.
https://mbparts.mbusa.com/oem-parts/...IFJlc3VsdHM%3D
1728200702
dealer invoice for center speaker repair on 2015 w212 E63 amg (part # 1728200702) under warranty. part can be bought from these MB Parts wholesales for $80 bucks https://mbparts.mbusa.com/oem-parts/...IFJlc3VsdHM%3D
