2014 63s Washer fluid warning/Ambient temp sersor
Old Feb 14, 2022 | 01:09 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
A few months back my ambient air temp sensor got hit and stop working --- or -40. Living in NYC I waited for a warm day/oil change. I also notice my washer fluid would not warn me when low or even empty. I was like that will wait till spring.
I installed new ambient sensor turned ignition on washer warning came on ... sensor took some time to report correct temperature since it was inside the house. I remove the sensor reinstall the old sensor ign on no washer alert. I then reinstalled the new sensor finish my oil change and the washer alert came on that I was low.
Seem like the washer fluid sensor and the ambient sensor are someone working together.
Old Feb 14, 2022 | 04:54 PM
PeterUbers's Avatar
Interesting!!
Old Feb 14, 2022 | 11:14 PM
Rehabguy's Avatar
E63S
Interesting indeed. Will make a note of this. Thanks for sharing this info.
Old Feb 15, 2022 | 09:03 AM
Mojo20032004's Avatar
2014 E63S
Is it possible because our windshield washer tank is heated that it turns on the heater based on what the ambient temp reads?
Old Feb 15, 2022 | 03:38 PM
sunil517's Avatar
100% verified
I did it again today when doing my trans fluid and and no warning...when the bad ambient. I am finally adding washer fluid to the tank.
These are the items that will make you go mad. I could see my myself trying to get to the washer tank.
