Vacuum leak ?
My car at idle it’s fine but when i press the brake paddel for 4-5 seconds the turbo actuator arm start moving open & close when i release the brake paddel 3-4 seconds the arm stop and stay close i already take a video for my problem!
Anybody know why this problem happened?
Anybody have this problem before in M157 engine?
https://usaupload.com/6gGg/IMG_5666.MOV
Maybe one of the check valve in the vaccum pipe?
Im confused when only happened when i press the brake paddel !!
Yes one more thing when i drive the car for around 30 minutes or 1 hour then i turn off the car after 30 minutes when i start it aging it’s do same thing wastgate moving for around 4-5 seconds then stop
If you can choose data to log, look for short term and long term fuel trims, and manifold absolute pressure sensor. I'm not familiar with that software interface or I'd try to help more.
Solved, The problem was in Vacuum pump Valve everybody keep your eye in this valve always it’s very common problem in M157
