Help with identifying the sound please
2016 E63 AMG S , 70K miles on it.
Took the tune off months ago.
I have been noticing a weird "slapping" noise that comes and goes. It's only present in idle really.
Please take a listen and let me know if you have ideas what it might be. And no I'm not talking about the valve lifter clicking (normal)
It's not under load so not likely piston slap
spun bearing and rod knocking is clearly what you're worried about and if this is a new noise that would be my concern
Lemme check mine
https://youtube.com/shorts/PQuUuOBXfSs?feature=share
I've taken care of mine very diligently but had some misfires with Eurocharged tune where it would start misfiring when I floored it from like 60 to 90 and it would then just continue misfiring hard on everything until I pulled off on the shoulder , turned it off and then back on.
It was weird .. .I wonder if those instances caused damage.
By the way, have you looked at what your wastegates are doing? If they are fluttering that may give you a noise like that.
Good luck.
Good luck.
https://youtube.com/shorts/pos2wOugMKw?feature=share
https://youtube.com/shorts/tToz1TlMMN4?feature=share
Also found an old Tasos video without any answers. Lots of commenters saying theirs sounds the same.
https://youtu.be/MFcBalt03e8
yea,.mine ended up being scored 5th cylinder. I ended up trading it in before it became a big problem and got a '19.
