2014 e63S - complete engine failure at 38,000 miles
I'm wondering if anyone has had this issue on an e63s. The car has was never tuned and never driven overly hard. I never even race started it, which is kind of a shame.
https://youtube.com/@TasosMoschatos
These engines are available some times with very low mileage for around $15000 and with another couple of thousand dollars, you should be back in the game in no time.
Good Luck
"They can't get the crankshaft to move" -
also how can they see the scoring in all the cylinders if they can't get the crankshaft to move?
These care great cars, just can't get enough of it though
*feel free to show any actual data on failure rates of the m157 by year since MY2011.
An 8 cylinder has more parts which will at least double the parts budget and time to put together, but not to the tune of 5x the cost.
Would be curious to hear what a good engine builder would approach this issue? i.e. can the block be salvaged? and then sourcing pistons/rods/crank (if you want), and then putting it all together.
Not looking forward to exploring this pathway myself, but if needed I would just get the engine rebuilt.
Not a lot of people are messing around with M157. A ton of people are messing around with EJ257. Look at how cheap LS V8 parts and builds are.
Agree it's not rocket science, but when there's only 1-2 rod and piston makers, low volume, and very few people that know exactly how the sleeves need to be done right. Add in most of the gaskets, weird lines and parts that are only available form Mercedes....
Even with OEM parts and aftermarket rods/pistons it seems cheaper to go the aftermarket route.
The builder that did my EJ257 was aware that it would be running 2x the original power, and it held up (still running strong as I sold it to a friend).
If I needed a rebuild I would use the same guy as it isn't rocket science.
Perhaps we should be swapping in LS blocks to replace blown M157s
I can’t emphisize enough the level of misdiagnosed cars I’ve looked at where dealer (or independent) suggested something catastrophic which turned out to be a much simpler issue.
Example, I recently had a friend’s wife who the dealer diagnosed a transmission replacement. $15k or so. When I looked at the car, I eventually tracked it down to contaminated fuel.
Now I don’t necessarily think they were doing it on purpose, it was just misdiagnosed. XENTRY had stored a bunch of different codes and they just took that data without question (as far as I can tell)
They may have replaced the transmission as they probably had enough profit built in, and then either had to eat the other parts they threw at it, or just billed the customer for the additional work justifying it as a needed repair.
Now I’m not saying all shops are incompetent, but proper diagnostic’s for complex issues can be time consuming and elusive. Techs are always under pressure to get the car out the door in a timely manner to turn a profit. And diagnosing a problem doesn’t always equate to the customer actually agreeing to spend the money on the repair.
It’s a double edged sword….
But before I would write off a $40k car or doing a $69k repair without question, I would definitely get a second opinion. I would bring it to another shop and NOT tell them the dealer’s diagnosis, but rather let the other shop give you THEIR diagnosis. Just tell them your car won’t start 🙂
Good Luck
In the part 2 Comments section Tasos says:
"I understand today why the engine is in this condition"
"Regular oil changes and used thicker oil (not the 5W-30/40)"
"10w"40?
OP, I wish you the best. Time to cut your losses. Choose wisely. I feel your pain.
