question for anyone who has replaced theit turbo coolant lines
Old Apr 28, 2023 | 04:14 PM
a1bray's Avatar
2006 cls 55 amg
Doing my waterpump, thermostat, oil filter housing and oil cooler gaskets. I noticed that the drivers side turbo coolant lines have the troublesome resin/plastic in their construction, but the passenger side turbo lines do not use any hard plastic. Are they failing as well for people? Are all you guys replacing all 4 turbo coolant lines or just the plastic ones on the drivers side. My car has 65k miles and none are leaking at this point. Any input is appreciated!
Old Apr 28, 2023 | 07:46 PM
log's Avatar
log
2014 E63S
It's been a while since I did that replacement, so my memory may not be the best on it. I think it's fairly common to damage the aluminum lines when disconnecting them to change the pump. I bought all the lines ahead of time, but got away with just using new o-rings on the aluminum ones. I do remember pulling all the coolant lines while the engine was still warm to the touch. Not sure whether it actually made a difference, but my thought was that the o-rings would be softer and release more easily.
Old Apr 28, 2023 | 07:56 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Lines are prone to break upon removal and would likely be needed to change in the future anyways. So save some time/labor/money by doing it all at once
Old Apr 28, 2023 | 10:28 PM
CZ 75's Avatar
E63 AMG
No need to replace the aluminum only lines going to the passenger side. Only replace o-rings on whichever ones you end up disconnecting on that side. It’s the plastic ones that eventually break and therefore those are a must do.
