TRANSMISSION HESITATION ?
https://mbworld.org/forums/w212-amg/...-2010-e63.html
Try re-adapting the mct wet clutch first - can do this with xentry I believe. You may need a new wet clutch as well:
https://mbworld.org/forums/w212-amg/...r-service.html
- do an mct readaptation
- reset the tcu
- try and drive another 2010 e63 somewhere to see if it's the same as yours to ease your mind
if only at a complete stop then it's a wet clutch issue most likely as the WC disengages when brakes are completely applied. It would seem
then that the wet clutch is not engaging fast enough and may be the hardware problem
