Oil pump solenoids
... on the m276 when it's in low pressure I understand the piston oil squirters are not active... wild stuff
only triggers it to be high pressure when above 3.5K rpm…?
I wonder on this forum who has driven the most with the solenoid plug, unplugged. Their recorded feedback would be much helpful.
Many reviews IMO seems to be speculations or even perhaps placebo.
(never unplugged)
(never unplugged)
if unplugged, it’s a constant high pressure at all times.
There's a video of someone tracking the oil pressure solenoid
I'm not an expert on all these engines, I just read this thread and made a decision for myself
Rock on
How many Miles since initially unplugged?
Is it time to upgrade better oil ?
ESTER in API-SP in 5w40 or greater.
So environmental / hitting government fuel efficiency ratings
will do 5w-40 next change in summer
Reduced oil viscosity is used for 10,000.Mi for the same gas savings reasons.
Limited engine lubrication does not radically impact its longevity below 100kMi.
> Side Effects Are...
- Weak engine throttle lag
- Tranny confused in low gears
- Engine blow-by pressure
- Extreme heatsoaks: coolant/oil leaks
- Loose metals ( cams; pistons; bores; bearings; VVT Locks)
- Killer solenoid stuck on low!
Driving under these conditions will make the engine weak with drafty pistons and lean fuel maps.... Lag + Misfires - It does save gas.
The stock experience all works out well with standard service.
I know you're familiar with misfires. Notice that new coils do not cure all of it, lean misfires come back!
Some misfires are caused by lean mixtures: the edge of the laggy ballpark when drafty cylinders becomes increasingly significant, even on boosted engines.
-- The NA engine is more sensitive to small pressure variations.
-- The TT engine can easily offset drafty cylinders with boost pressure.
-- Low viscosity oil does not effectively spray seal below 2200.Rpm
There's no seal improvement on stock oil. You're going to need to step up viscosity when your rings meet your cleanliness criteria.
Motivations to upgrade may be:
- heavy slow pickup
- laggy spongy throttle
- goofy tranny gear ratio
- lean misfires fish bites
- extreme heatsoaks
If you like numbers observe your LTFT at warm idle. It's a marker of cylinder wear.
Under improved conditions, pressure still vary between low and max. The idle pressure is very similar in both cases. It just increases on a faster slope.
We've seen hydraulic VVT gear and piston rings benefit from better oiling. This is delivered with higher viscosity ester oil.
https://www.liqui-moly.com/en/us/syn...0345.html#2041
Would you consider jumping from that to the 5w50 supercar ( ) a reasonable next move?
Motor on
Would you consider jumping from that to the 5w50 supercar (https://www.amazon.com/dp/B0BWPLYYTT) a reasonable next move?
You will have a great experience with the Mobil1:5W50 Supercar oil.
We've reviewed it here.
It has a nice balanced protection package based on high temperature ester oil. Meaning this will truly keep your engine clean & protected.
Its's a good upgrade path from the LM:5W40 SN you referenced above.
> POST Upgrade:
Your engine/tranny maps will temporarily act a bit confused below 2000Rpm for about 500Mi until ECU/TCU perfectly self-adapt to new performance level.
Frequent 30Mi trips will be better than one long one.
You will notice throttle getting gradually more precise - Same for tranny matching the engine improvements.
By the time improvements are done... pressure sensitive throttle will be exhilarating with rich responsive mixtures from 900.Rpm where lean-lag used to anchor.
This should quickly become available with regular driving.
+++ Do clean your filter bypass valve during oil filter replacement.
A pressure sensitive throttle on a twin turbo... OMG ultimate city/Hwy driveability
+++No questions Turbo always put out power above 3k, this is going to fill in the lower range when significant losses impact fuel map by way of timings jitter.
> POST Upgrade:
what oil did you use on your last oil change, current and next oil change, what will you use?
past and current oils
800Mi on MOT.5W50 👍
Next oil may be a repeat 5w50 in Motul or a Castrol, Pennzoil, Mobil1 or a 10w50 if viscosity shear on MOT:5w50 is significant.
Every new oil starts great then falls of the clif at some point... Motul has been tought
Definitely within W50 range for sure.
The happy median is to have enough viscosity reserve that it can shade a bit without being to noticeable early.... 4500Mi ok.
I want to drive a stable 0w50 so I begin with a 5 or 10w50 later.
