40 degree mark worn off
Old Dec 23, 2023 | 06:27 PM
max.gibson's Avatar
2013 Ml63 AMG
Need to set timing for my M157 however my 40 degree mark is completely gone. Anyone have some advice for methods of finding 40 degrees and creating a new mark? Thanks!
Old Dec 25, 2023 | 12:40 AM
Mojo20032004's Avatar
2014 E63S
Buy a new crank pulley and replace the existing one? Once center bolt is removed, pulley slides off.. Pulley isn't timed, the crank inside is, so you should be able to swap pulleys without having any effect on timing. Also pulley fits one way because of the keyed inside
Old Dec 25, 2023 | 02:15 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
time the engine where all four cam wheels apear in time through CPS windows... 40 is thirteen degrees earlier than that.
Perhaps crank mark become more visible then. A new balancer pulley is guaranteed to save your time.
Old Dec 25, 2023 | 03:55 AM
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
Get a timing degree wheel and put a new mark or center punch it.
Much cheaper than a new pulley.
