Increased fuel consumption
I have scanned the car a few times (iCarsoft CR Max, not Xentry) and there are no codes. I have changed the engine oil and filter and air filters. The brakes all feel the same temperature across the same axle and not hot when I've finished my journey. When coming to a stop I have been selecting N to make sure the car still rolls and isn't dragging.
I think this started after I went through some water a couple of months ago. The road home was flooded in a few places. I may be clutching at straws but, if water managed to get in the exhaust system through the wastegates would it affect the Cat's without throwing any codes?
Has anyone got any suggestions for other things I should check?
It's a lot colder lately here, so the car takes longer to warm up, meaning increased fuel injection to compensate for condensation. At least in our region.
The water would have gone through your air filter first. You said you replaced it and found no dampness?
Pictures of the Rufford ford comes to mind. Hope you didn't pull something like that.
With the engine running, water won't reverse flow from the tailpipes into the engine.
My advise would be to check the average fuel consumption reading on the display. How low is the mpg when you first start and how long does it take until the engine oil is warm and fuel consumption drops to normal. At such low speeds in the UK, I'd think this can take a while.
I just recently had a 50 mile trip and it took at least 30 miles for the engine to completely warm up, going speeds at 50mph or lower with temps in the high 20's F. My average fuel consumption was pretty high too.
I don’t think any water will have/could have gone up the exhausts. I’m just wondering if any may have managed to get in through the turbo wastegates. I didn’t check the air filters at the time. I’ve changed them now to help with troubleshooting.
It’s been getting steadily worse since the water.
I’d wait until warmer weather to see if it goes back to what you’re used to seeing vs digging into a problem that might not even exist.
Read both your engine lambda and cat oxygen sensors.
Do that couple times to compare results for a lazy participant.
Combustion sensors are super heated ceramics and don't like thermal shocks.
