More Questions on Mounts!
I think I have discussion thread overload, yet I don't seem to be able to reach a conclusion on the following:
1. Which motor mounts should I use? OEM - which have had longevity issues. Boosted Benz - the old ECE design that had melting issues, but now comes with shielding. Creative Steel has one, but also having issues on and off due to the heat. I am thinking OEM is still the best bet at this point, unless someone has any other knowledge to bestow on me. And I would appreciate it.
2. Transmission mounts. Appears that the OEM mounts are the only ones out there for our cars. Nothing on boosted Benz or creative steel's pages. Is there an aftermarket out there? Everything I found appears to be OEM replacements.
Thanks in advance for any help/advice!
Scott
Scott
Hey! That's correct, at AXE Euro we provide engine and transmission mounts that are stiffer and last longer than OEM mounts. If you're interested please PM here or check out our Facebook page.
W212 E63S Wagon - GSL580 - E63 - E350 - C300
OEM and OEM....period. No one can quantify a reason not to go OEM. Sure, folks claim lots of things. With OEM you know 100% what you will get and how long they will last.
Baltistyle (02-29-2024)
Obviously my comment only holds so much weight since I don't have 100k on these mounts, but if heat hasn't cooked them already then I'm hoping they do indeed last that long (and if not, further replacements just require swapping out the internals which is far cheaper than entire new sets of mounts). So, if they last as long as OEM, then they are cheaper in the long run.
On transmission mounts - I don't really see a reason to go aftermarket if you get stiffer engine mounts as they will greatly limit the travel and OEM will more than suffice. If it's the other way around, I also don't see any reason to get a stiffer trans mount on OEM engine mounts. So either way I'd stick with OEM there.
Your decision should come down to feeling - if you've had cars with stiffer mounts in the past it will feel like that, a little more vibration through the steering wheel but a more connected feeling to the powertrain. I can powerbrake and rev while watching the engine and it doesn't move an inch, but it also doesn't feel like a racecar running solid mounts, so I'm quite happy with the BoostedBenz ones. The only change I needed to make was adding urethane exhaust hangers as they sit just slightly lower than stock and the exhaust in front of the resonator would sometimes hit the crossbar. That's now fixed and the urethane mounts were like $14 on Amazon, probably better for the car in the long run anyway. Just my $0.02!
The following 2 users liked this post by GinDistiller:
OldManAndHisCar (02-28-2024),
Rehabguy (03-01-2024)
