W212 e63s m157 thermostat has oil and water mixed
Old Aug 15, 2024 | 06:33 AM
Kawa63's Avatar
W212 e63s
i have a w212 e63s 2014 the thermostat was replaced 2 years ago working on the car to change a oil thermostat cover had to take the thermostat off and i would that in that but i havent lost any coolant i will do a gaskit pressure test once in put everything back but has someone had this issues ? Engine has no water and oil mixing up lose normal
Old Aug 15, 2024 | 07:45 AM
JettaRed's Avatar
Veteran: Army
If you think you have a cracked head or leaking head gasket, you can do a simple test for exhaust gases in the coolant reservoir.
Old Aug 15, 2024 | 01:58 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Oil in water is survivable but the opposite is an engine killler.
Overheated seals deliver :
  • timing chain cover seals
  • engine oil heat exchanger
  • coolant radiator with exchanger
Where is your oil meeting water?
