Misfiring M157
Please ask me questions to narrow down the issue.
Things I'd be looking at are all air, fuel and ignition related voltages, pressures etc. Following that it could be a harmonic issue causing some noise in the system however I highly doubt it.
I also want note that I recently changed coils and plugs with ngk iridium high performance plugs, also my car is stage 2 tuned so its got downpipes and intakes, also want to mention that my car doesn’t reach full boost for whatever reason, after my stage 2 tune it would go past 18psi but now ever since i got the issue it won’t go higher than 12psi.
here are some logs I recorded, you can see that when im at full throttle fuel pressure dramatically drops but as soon as i let off it returns to the normal threshold, even at half throttle it maintains pressure
Is your intercooler pump working? 60 celsius is about 140* F, that is way to high and will cause the car to pull massive timing to save itself
Yeah it is, it’s just that it’s quite hot where I live, and the stainless steel intake doesn’t quite help with that cause it heat soaks so im planning on installing the oem intakes back.
What you're describing suspiciously sounds like failing camshaft magnetic adjusters. Often when they are going out, it cuts fuel exactly as you're describing and throw multiple codes including fuel lean codes because the car was at WOT when also being thrown into limp mode because of the throttle position. Had they bothered to do a proper diagnostic of the sensor values key on engine on, they would have notice a variance between the 4 sensors.
Common issue. Check the plug ends for oil wicking. Replace all 4 sensors if good and add pigtail extensions. For additional insurance, and due to ease and common near simultaneous failure, I also will recommend replacing the cam position sensors with pig tail extensions as well assuming no oil wicking is present.
https://mbworld.org/forums/w212-amg/...sors-leak.html
