Water pump pulley
Old Apr 11, 2025 | 04:37 AM
jcarsnz's Avatar
Water pump pulley
Bought a new water pump and noticed the pulley does not spin freely like an idler does, instead there is some resistance when turned by hand.
Is this normal for a new water pump, and to be expected?
Or was buying an el cheapo after market part my mistake here.
Old Apr 11, 2025 | 01:45 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
What brand or where did you buy it?
Old Apr 11, 2025 | 08:00 PM
jcarsnz's Avatar
Graf water pump, purchased here
https://spareto.com/products/graf-water-pump/pa1560
Old Apr 11, 2025 | 09:43 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
An idler is just a single bearing spinning. The pump pulley is spinning the shaft and impeller as well. More stuff to move. Obviously if it were electric it would be different.
As long as there is no grinding or resistance you should be good.
New bearings should not allow a pulley to spin and spin because the grease inside offers resistance. A metal pulley with more weight will spin a little bit more. A pulley spins very freely with speed and noise once all of that grease is gone, and at that point it’s dead.
Old Apr 11, 2025 | 10:40 PM
jcarsnz's Avatar
Thanks for the explanation.
Old Apr 12, 2025 | 03:00 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Graf is THE correct choice. I haven't had a bad one in the 30 I've ordered. I've had bad REIN/Vaico though. Mahle/Saleri are also correct.
It's supposed to spin real tight, it's how it keeps pressure. The uh vanes have a tight tolerance and when the bearing lets go it wobbles which digs the vanes into the housing and frees up tolerance.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Apr 12, 2025 | 03:49 AM
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
Plus the resistance of the seal, which is what you'll feel the most, when turning by hand.
Old May 3, 2025 | 01:29 AM
zk2004mb's Avatar
S63 Coupe
Relax, it's normal. I can tell you the genuine MB M157 WP spins the same way as you described.
I still have a new one sitting in my garage. PM me if anyone is interested
