Looking for a good shop
Old May 19, 2025 | 01:28 PM
Dnice24's Avatar
E63 AMG S
Anyone in South Florida have a recommended shop I can take my car to for a tune up and taking care of an oil/coolant leaks?
Old May 19, 2025 | 05:51 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
venting out pressure
Both oil & coolant leaks will keep venting pressure until you manage to prevent heat accumulation in pistons.
No1 item to deal with is $49Ea. 4x cam sensors to prevent "$10k oil-in-harness" when oil spreads throughout electricals.
PCVentilation conduite can get obstructed by oil residues given sufficient mileage.
Old May 19, 2025 | 06:06 PM
Dnice24's Avatar
E63 AMG S
Oil is in the first sensor (left side when looking directly at the engine bay). All other ones are dry.
Old May 20, 2025 | 12:34 AM
COOLING PLASTICS OPTION
This is called Bank1 Exhaust CPS: good catch!
The other 3 will be wet if you sneeze twice.
It's like most maintenance: change all found bad parts at once.
You need to keep all your cylinders running as equally as possible.
Check but keep your "VVT Solenoids": they usually stay okay unless engine got beyond extremely hot.
You really best to avoid oil travelling around tge whole engine bay harness.
Heatsoak is the enemy once engine stop... it's not a bad idea to pop hood to help preserve engine plastics... or cancel stock heat accumulation.
Old May 20, 2025 | 02:06 AM
streborx's Avatar
Top Answer: 1
G550
Start with benzshops.com and enter your zip code. Then call and ask about their capabilities.
Old May 20, 2025 | 08:13 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
How South? I know of three places near (or north) of Orlando. One in particular wins all kinds of awards with MB and Porsche.
Old May 20, 2025 | 08:50 AM
Dnice24's Avatar
E63 AMG S
A friend of mine brought this to my attention. Eventually i’ll be changing all sensors to prolong the ecu. Thanks for the info!
Old May 20, 2025 | 08:51 AM
Dnice24's Avatar
E63 AMG S
Thank you! I will look into it. I’m looking to get something done before I buy my next home.
Old May 20, 2025 | 08:52 AM
Dnice24's Avatar
E63 AMG S
I’m located in Boynton Beach. About an hr from Miami.
Old May 20, 2025 | 09:26 AM
Yeah, you are way down there. From what I understand, tons of shops in the region.
Old May 21, 2025 | 01:32 PM
JettaRed's Avatar
Veteran: Army
Old May 23, 2025 | 10:08 PM
Rehabguy's Avatar
E63S
@Dnice24
I have a set of 4, brand new CPS I got from FCPEuro I never installed in my car. PM if you are interested in buying them.
Old May 23, 2025 | 10:59 PM
Dnice24's Avatar
E63 AMG S
Originally Posted by Rehabguy
@Dnice24
Thanks. I actually bought them already. I need to buy the solenoids.
