E63S M157 which oil level sensor trust ?
Old Jun 3, 2025 | 12:46 AM
thparent's Avatar
S212 E63S 2014
Hi,
It seems that 3 different methods could provide the engine oil level on a M157:
  1. Oil dipstick (engine at temp after 5 min off)
  2. Dash cam error message (add a quarter...)
  3. Xentry oil level reading
Which one could be considered as the most reliable (my guess the 1. but is it not potential "clog" or fluid circulation issue)
On the basis that the Dash cam error appears and that the dispstick and xentry are not detecting any level issue, does it mean that :
  • There are 2x oil sensors. One used for dashcam warning and a second distinct one used by Xentry ?
    In other words : the dashcam could be faulty when the Xentry could be OK, matching the dipstick
  • Dipstick is always right (when measure protocol is applied) ?
Thank you so much
Thierry
Old Jun 4, 2025 | 02:29 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by thparent
Hi,
Thank you so much
Thierry
the oil dipstick never fails - Engine oil level sensor on the other end is known to get temperamental.
Oil level is normally a non issue unless oil keeps disappearing...
Old Jun 4, 2025 | 07:13 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
the oil dipstick never fails - Engine oil level sensor on the other end is known to get temperamental..
And when this old man purchased a nice brand new Mercedes with NO FREAKING DIPSTICK....well, he gets temperamental......
Old Jun 4, 2025 | 11:22 AM
sensor... no stick
+ the oil floater goes disco lights... that's upsetting !
Old Jun 4, 2025 | 11:58 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
I have noted that when the dipstick reads about half a liter low the oil level light will come on if I do a sustained pull. Does not have to be hard, just mid-range in the revs. I figure it is filling up the upper engine and it triggers the level sensor. If the dipstick is at the top of the range, this does not happen. I usually do not worry about the warning as it shows "add a quart" or something like that. I have not cross-checked with Xentry.
Old Jun 4, 2025 | 12:09 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
a combination of the first two
the dipstick can be unreliable unless its level, hot, and you've done 3 wipes after engines been off, but theres oil in the turbos, the heads, etc
sometimes itll tell you its low and to add a quart when you stop hard downhill or give it a good rip on the freeway, youll get to level ground, and everything will be quite fine just add a splash anyway as a buffer
you don't wanna go 2 quarts over though, you'll get aeration from the overfill/positive crankcase pressure which is not great. If you get air in your oil you're stripping the oils ability to provide hydrostatic lubrication
I've been filling MB's about a half quart extra on my personal cars my whole life. Business cars get exactly what it says they should. 9.5 goes to 10, etc. Porsche people have been doing this forever.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 4, 2025 | 01:17 PM
@ChrisHimself We do all know....more is more...
Old Jun 4, 2025 | 01:39 PM
thparent's Avatar
S212 E63S 2014
Thank you so much.
So, as an old man, I will continue to trust the oil dipstick (which is giving a lower level when engine is cold (half) than when it is warm (full).
I guess that it is temp related.
