S212 E63s Stealth Hitch install
Old Aug 7, 2025 | 10:32 PM
Rickflair01's Avatar
2015 E63s
Since buying a wagon a few months ago I've been looking to adding my hitch mounted bike rack to get the kids to the trails. Emailing back and forth with Stealth Hitch, they don't make a Hitch that will work with the E63s. I swore I have seen others on here with hitch mounted bike racks. They say their hitch will work with the non-AMG version.
Anyone have a different experience or know if the Hitch will work on the E63s?
Thank you
Old Aug 7, 2025 | 10:53 PM
PeterUbers's Avatar
I've only known it to work on the W-213 AMG
https://mbworld.org/forums/w213-amg/...lth-hitch.html
yet there are these pics of it on a 212 maybe amg
Old Aug 8, 2025 | 06:25 AM
2015 E63s
I have seen another as well.
Old Aug 12, 2025 | 10:57 PM
southiemerc's Avatar
2015 E63S AMG Wagon
Can confirm my 2015 E63S wagon has a Stealth Hitch, installed by previous owner. I have not used it but sleep well knowing I can LARP as a triathlete or outdoorsman if the need arises. Here are a couple pics. Truly would not even know it was there if he hadnt told me.
Old Aug 13, 2025 | 06:55 AM
2015 E63s
Wonder if any extra modifications were needed to achieve this? Do you have stock mufflers? I would see that as the real limiting factor.
Thank you
Old Aug 20, 2025 | 01:30 AM
2015 E63s
Bump to the top. Looking to tackle this but need input from other E63s owners if this hitch will bolt up on the AMG platform.
Thank you
Old Aug 20, 2025 | 12:59 PM
AngryScotsman's Avatar
E63S
Yes, it works well. It tows better than my 2g Tundra.
Old Aug 21, 2025 | 09:37 AM
2015 E63s
Thank you!
Old Oct 9, 2025 | 02:20 AM
tude's Avatar
2014 E63s Estate
I know this is a few months old, but I believe I have a stealth hitch on my E63 Wagon S212 .
Old Oct 9, 2025 | 06:57 PM
2015 E63s
I have confirmed that this application does work. I order the Stealth hitch after the feedback here and have it installed. I don't have any good pictures of it yet but it does indeed work.
Old Oct 9, 2025 | 07:05 PM
PeterUbers's Avatar
Thank you
and to close the loop, were there any modifications you had to make? How did the install go? Was the install exactly as the non AMG?
Old Oct 10, 2025 | 06:37 AM
2015 E63s
I had a local shop do the installation as i had them doing some other things at the time. It took them 3 hrs. I was told lots of removal and replacement of interior components. I really didn't want to mess up the cutting of the diffuser.
Install as was quoted. Stealth doesn't list the AMG version on their page as they have not put the R&D into a lower volume trim. The worry was the potentially larger exhaust or length of drop for the hitch. Therefore, they just don't list it as compatible.
Old Oct 10, 2025 | 11:04 AM
PeterUbers's Avatar
this is significant feedback - thanks
Old Oct 10, 2025 | 12:40 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I have a hitch on my W212 (11) but not the other one (14). I forget what brand it is...it is not "invisible" but is super handy for my bike rack (with a 1.25 to 2" converter). It is no where near as solid as the mount on our 3500 or GLS.
Old Oct 10, 2025 | 10:02 PM
2015 E63s
Quite welcome
Old Oct 12, 2025 | 10:10 AM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Did they have to trim the diffuser?
I had a shop install a hitch on our X3 and they had to trim a 2" x 1" out of part of the rear bumper, only seen if you lay on your back and look up at the hitch.
Curious if they had to trim a similar cutout on the diffuser? Any pictures from the rear and the 'bottom'?
Thanks for the info @Rickflair01
Old Oct 12, 2025 | 12:57 PM
2015 E63s
Old Oct 12, 2025 | 12:58 PM
2015 E63s
They did have to trim a cutout. Looks similar to the attached. I have not taken any pictures of mine but these were both from other E63s.
Old Oct 12, 2025 | 01:14 PM
PeterUbers's Avatar
Added to the sticky
Old Jan 27, 2026 | 06:19 PM
PnwGLS's Avatar
2024 MB GLS580 , 2016 E63 S AMG Wagon, 2011 BMW M3 Sedan
Very cool - I had one of these on my SQ5. Not sure I'll take the plunge on my wagon but good to know its an option.
Old Jan 30, 2026 | 10:17 AM
E63S
Recently was asked about my install. Here's more notes about it:
Just be aware of a few things:
- The wiring is a bit... wonky. 4pin Uhaul type of wiring, easy. 7pin, more complicated.
- The hitch requires that one of the vanes on the diffuser to be trimmed. This is hardly noticeable, but worth mentioning as it's the one thing that makes this irreversible.
- The hitch replaces the bumper beam. Save the bumper beam though, as if you want to reverse everything, finding a 2014 bumper beam is very very difficult or very very costly. The AMG bumper beams ARE different than the non-AMG cars.
- I used one of the auto transport Uhaul trailers, notorious for being on the heavier side (ie. 2200-2500lbs). Both the trailer and the Noble put the tow weight at around 4500lbs... the wagons weigh 4700lbs, so you want whatever you're towing to be less, generally. Either find a lighter trailer or opt for the motorsports trailers that Uhaul has coming out (or released in some places).
- The wagon towed better than a 2012 Tundra I have. The wagon could tow at 80mph without a problem, up a 5% grade. It drank a lot of gas doing it, but it could maintain 80mph.
- If you use any of the lane keep/parking features, they will go a bit weird when trailering. You can use cruise control, but it may go into fault up a hill or if the trailer isn't loaded correctly and you won't have cruise control.
- Brakes are more than enough to stop. I had to panic stop one time due to an accident happening in front of me. Stopped without much drama.
- I would just keep an eye on temps on hotter days and up hills, especially long ones.
- It was EASILY the best modification to the car. Turned my wagon from being useful to being truck like. I could grab a utility trailer and load it full of home depot supplies and still have the interior for whatever.
- I checked the hardware where it bolts to the car, as well as any other hardware before / after almost every tow event, just to make sure nothing got loose or was bent, considering I was using the system in a way it wasn't necessarily designed. I removed the hitch before selling the wagon, and the frame was still as it was before, with the bumper beam bolting up as it should. This was after about 6000+ miles of towing.
Old Feb 27, 2026 | 02:40 PM
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
Regarding Stealh Hitches and AMGs, it's true that they don't list AMGs on their site because they don't get them in-house to test with. They don't promise fit. I just installed one on my C43 sedan, read here:
https://mbworld.org/forums/c450-c43-...-2017-c43.html
Old Mar 25, 2026 | 07:30 PM
timotat's Avatar
GLE53, 392 Wrangler, 2 Harleys
@AngryScotsman Thank you for your pictures and review. Getting Mercedes to install a hitch on my AMG GLE 53 Coupe when it was not factory installed met too much resistance and Stealth appeared to be my best option, but no listing for my 2025. I am heading to their site in Atlanta in a couple of weeks to have them install their rack & tow package. I think what they have should fit as they list to a 2024.
