Engine Stalls going into gear
Old Nov 16, 2025 | 12:44 PM
BlobSagget's Avatar
2012 E63 Wagon
My 2012 E63 Stalls going into gear. Starts and runs fine in park and neutral but as soon as I go into drive or reverse it shuts off. Let it run for about 10 minutes and get up to temp and it still happens.
Ordering a scan tool now to see if it says anything, just asking around here to see if anyone knows anything.
Old Nov 18, 2025 | 07:48 PM
BlobSagget's Avatar
2012 E63 Wagon
KLA(Air Conditioner Control Unit)
A10D21 Moderate
Status: Stored
The power supply is too low. The signal amplitude is less than the minimum amplitude
DSI(Shift Lever Control Unit)
P085011 Severe
Status: Stored The button 'Gear range P' has a malfunction. There is a short circuit to ground
ABA(Front Radar Sensor)
755800 Moderate
Status: Stored No CAN message was received from 'CE11 (Left front door control unit)`.
755900 Moderate
Status: Stored No CAN message was received from 'CE21 (Right front door control unit)
530400 Moaderate
Status: Stored Radar sensor 3 is disrupted by interference from an external transmitter.
520400 Moderate
Status: Stored Radar sensor 2 is disrupted by interference from an external transmitter.
580400 Moderate
Status: Stored Radar sensor 8 is disrupted by interference from an external transmitter.
550400 Moderate
Status: Stored Radar sensor 5 is disrupted by interference from an external transmitter,
RBTMFR(Passenger Seat Belt Tensioner Control Unit)
640300 Serious
Status: Stored Software error
PPMKS(Multicontour Seat Pneumatic Pump)
9010 Moderate
Status: Stored The power supply is too low
9251 Moderate
Status: Stored Leakage
MKS-FL(Left Front Active Multicontour Seat Control Unit)
9EA953 Moderate
Status: Stored Multicontour Seat (MKS) pneumatic pump faul component deactivated
MFK(Multifunction Camera)
A3A813 Moderate
Status: Active and stored The output for window heating has a malfunction. There is an open circuit
DTA(Telematics Service Control Unit)
D691 Moderate
Status: Stored, An implausible wheel speed signal was received.
DAB(Digital Audio)
D250 Moderate
Status: Active and stored The radio service 'SIRIUS' is not activated.
These are all the codes. Feels like P085011 is the most likely culprit of these, but everything else about that code online says that it's usually just the park button going out (Which has been the case for me). Seeing as the car starts and runs fine, and does attempt to go into gear (the camera comes up when going into reverse and the dash shows second all before shutting off), then this is probably not the issue. Going to have to take it to one of the shops and see if they can find anything.
Old Nov 18, 2025 | 07:58 PM
PeterUbers's Avatar
I'm not sure what's causing your issues but the first thing to check is whether there is oil in your main engine harness and is there any oil around the pins of the ECU.
Additionally, did anything happen before this will happen, it was the car just driving and shifting fine and all of a sudden one day you wake up and the car won't shift to drive?
when's the last time you replaced the main battery?
Old Nov 19, 2025 | 11:00 AM
I.T. Guy's Avatar
2023 E63S Wagon
Does it clunk and physically stall mechanically or does it just 'turn off'?
