Winter setup
#254
#255
Winter set for E63 CCB
https://mbworld.org/forums/market/786981
I am looking for a winter set for my 2018 edition 1 E63 with carbon ceramics. I found this set from S63 in the MBworld market.
it is 285/35 and 255/40 with stock S63 20” from what I could figure out.
Any idea if this will be a good fit? thank you for checking.
#258
go fast grocery getter wagon
just based on calculations POV.
front: s63 wheel will appear to be more tucked into the wheelwell by 27mm. Hence, you may want to consider wheel spacer, say up to 15mm. Tires wise, your speedo will show 3% slower than what it actually is. Ride height will increase by 9mm as well.
rear: s63 wheel will appear to have extended outward by 10mm. I don’t believe it will cause any fender clearance issue. Tires wise, your speedo will also show 3% slower than what it actually is. Ride height will increase by 11mm as well.
in theory, they would fit.
atk47 (06-25-2020)
#259
#260
btw, please be careful with those wheels as they may be replica. You will need further proof from seller that they are the real Amg wheels. Ask for pictures in the inner barrel of part # stamping and wheel manufacturer . typically BBS made in Germany is the primary maker and there should be stamped as well . Without any of these, the wheels are worth only fraction of the asking price. If they are replica, they may not clear your CCB
atk47 (06-26-2020)
atk47 (06-26-2020)
#262
After some discussion with SA and Tire Rack, ordered the Pirelli Sottozeros. 4x 255/40R19
https://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=Winter+Sottoz ero&partnum=54VR9240SZXLV2
Also ordered these recommended wheels - which are somewhat similar to the OEM wheels.
Look for the Flow 1 F2 Gloss Black - other link was not working.
And ordered tire pressure monitors for $160. All in with shipping was $2,249.
