W213 M178 E63 AMG Downpipe kit
#101
> Remove OEM down pipes and install the new ones.
How do you remove OEM downpipes without dropping tranny and without welding/cutting into the stock downpipes?
417win (04-30-2019)
#102
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
All this info had been posted on post no 27 in this thread with pictures.
#103
Sorry to be pedantic but uh.. after you cut the stock down pipes out, you gotta like... weld the new ones, right? aka, there is welding?
#114
PLATINUM SPONSOR
These are W213 E63 down pipes installed pics at the links below. UPD High flow air filters comparison pics as well.
Also on IG @ultimate_pd
Facebook Post
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#115
#117
Tunes are labeled as Stage 2 for cars that have downpipes.
This is what I have seen when customer who already have a ECU calibration add downpipes, they pick up a lot more power after the EUC is flashed with a Stage 2 ECU calibration.
#120
if you don't drop the trans to install them, are the stock downpipes ruined in the removal process or are you able to put them back (aka when you return your lease lol)
