Edition 1 : Check Engine Light + Hiccuping Shifts
Old Apr 30, 2018 | 12:55 AM
JohnnyM57's Avatar
e63 ed1 / 911 GTS Cab
Hi Guys,
Went to California for 1 week with the family. Came back over the weekend, and hopped in the e63s. Car turns on fine, I pull out and notice the engine hiccuping, throttle not really responding well. Very strange. Look at my dash and sure enough the check engine light was on. Turned around and parked the car. Tried multiple times to see if anything will change if I turned the car on and off, drove in my drive way a bit...same engine/tranny weirdness. Im having it towed to the dealer tomorrow AM.
What should I direct them to do? (assuming they give me the ol' "everything looks good bs")
Side note: Just had 1st service done (after the rear diff change). Gas is full. Gas cap ok. I filled my Porsche Carrera GTS with same gas from same place and its running fine.
In review: Engine def vibrating more, seems like throttle not corresponding to how I press the pedal, and hiccuping shifts from 1-2-3. Check Engine Light On.
Old Apr 30, 2018 | 10:35 AM
PeterUbers's Avatar
Just let them do their thing, presumably this is a reputable service department. You don't need to do much more than get the car to them.
Old Apr 30, 2018 | 10:52 AM
dav461's Avatar
GTR
You have warranty on your car. Doesn’t matter what people here will write and suggest, dealer will do what they think is necessary to fix the problem. So asking for advice and some sort of “help” is useless.
Old Apr 30, 2018 | 02:27 PM
limeypride's Avatar
2018 AMG E63S
Originally Posted by JohnnyM57
Hi Guys,
if there's a CEL, they have everything they need in conjunction with your description of the symptoms.
Get her booked in...
Old Apr 30, 2018 | 03:36 PM
Carac's Avatar
2018 E63S Wagon
I'd ask if they had updated any software. MB has been rolling out a lot of updates for the M177 recently.
Old Apr 30, 2018 | 06:15 PM
dav461's Avatar
GTR
Dealer can’t update software anymore without real need for it, eg you have to complain on engine, transmission that they are working bad in order for them to get updates
Old Apr 30, 2018 | 06:18 PM
Carac's Avatar
2018 E63S Wagon
Well then, it sounds like he needs to complain to get these updates with the rolling code improvements they’ve been making over the past year.
Old May 1, 2018 | 03:31 AM
guhvies's Avatar
2017 C43 AMG Saloon
Make sure you take it out on a test drive with the SA & mechanic that worked on it to make sure all is well before driving home...
Old May 2, 2018 | 11:37 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
There will be codes stores in the ECU
