Standing Burnout
I only did it once. And then I tried it countless times and never made it again.
https://youtu.be/QbqAWUWwxSY
D000rifto (03-19-2022)
Has anyone tried doing this in manual mode? This is assuming manual mode is available on the W-213
#32
I just found out yesterday (after damn near 4 plus years with this car) that I could do a standing burnout, only in manual mode though
Maybe Racemode?
#33
2018 E63S AMG
There is a manual transmission mode selection button on the center console. This button must be activated in order to enter drift mode. The traction control must be off, and the car set to race mode. Once all that is done, drift mode can be selected.
The car is pretty much manual then . . .
#34
#35
Just did standing burnout... only one problem there - tires, I want to keep them for a long time, but drift mode is too funny to use
#37
kponti (10-12-2018)
#38
My W212 does the same thing (albeit some do it without moving forward)
Mandarin (10-12-2018)
#40
2018 E63S AMG
I'm confused - if you roll you're not stopped/standing.
Seems like it's still true that the car will not do a standing burnout. It requires some forward movement before the wheelspin starts, then by tapping the brakes the forward movement is slowed or stopped.
It's mainly academic to me as I mostly got over doing burnouts in my teens, but never lost the desire to do the occasional power slide ;-)
My front tires are about done at 9,000 miles but I think I can stretch them another thousand or so. Oddly the rears have more tread remaining than the fronts. When it's time to slap on a set of Michelins and get rid of the Pirellis, I will happily engage drift mode and send the remaining rear tread to tire heaven
#42
Rolling burnout:
Standing burnout:
e63s burnout (I did the same):
#43
#44
Reviving this thread to see if anyone has any additional tips on getting this rolling/standing burnout to work. I can't seem to get the rear tires to break loose like shown in these vids. Is this all in first gear?
#45
Put it in 1st gear, turn off all the traction control, hold the brakes just hard enough to activate the front brakes and not the rear (most brakes are biased 70/30) and it's kind of a balance between pushing the throttle to initiate wheelspin and pushing the brake just enough to keep the car from moving forward.
